How to Repair a Frayed Headphone Cable
    1. How to Repair a Frayed Headphone Cable, Cable: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Repair a Frayed Headphone Cable, Cable: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Cut above the frayed portion of the cable using wire cutters.
      • Using the wire cutters, strip away approximately one inch of wire coating.
      • Use caution to avoid cutting too far into the wire.
    2. How to Repair a Frayed Headphone Cable: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Repair a Frayed Headphone Cable: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • After stripping the wire, four wires should be exposed. The wires should be three different colors.
      • Red: Right channel
      • Gold/copper: Ground
      • Blue/green: Left channel
      • Twist the two ground wires together.
    3. How to Repair a Frayed Headphone Cable: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Repair a Frayed Headphone Cable: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Unscrew the plug housing.
      • Thread the wire through the plug housing.
    4. How to Repair a Frayed Headphone Cable: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the enamel from the red and blue wires with a wire stripper.
    5. How to Repair a Frayed Headphone Cable: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • With a soldering iron, apply a small amount of solder to the end of each wire.
      • This is especially important for the twisted ground wires; the solder should hold them together.
    6. How to Repair a Frayed Headphone Cable: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Repair a Frayed Headphone Cable: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Repair a Frayed Headphone Cable: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Thread the wires through each hole and wrap them back over.
      • See the third picture for a diagram of where each wire goes.
      • Next, twist each wire with itself to secure it to the lead. This can be seen in the second picture.
    7. How to Repair a Frayed Headphone Cable: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Repair a Frayed Headphone Cable: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Solder over each lead's hole, connecting the wire to the lead.
      • Your solder joints should completely cover the hole and surround the wire.
      • After each wire is connected, use a drop of hot glue to secure the wires and prevent them from touching each other.
    8. How to Repair a Frayed Headphone Cable: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Screw the housing back onto the jack and test your work.
      • If the sound turns on and off this is a connection error. To fix it, look at your solder joints and make sure the wires are fully connected to the leads. If not, apply more solder to the joints, covering the wire.
crwdns2935229:043crwdne2935229:0
Tyler
crwdns2935283:002/24/15crwdne2935283:0
956 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 23-2, Green Winter 2015 crwdns2935289:0Cal Poly, Team 23-2, Green Winter 2015crwdne2935289:0
CPSU-GREEN-W15S23G2
crwdns2935297:048crwdne2935297:0
To me, the more difficult part in this job, is solder.... Now, If you are not sure, with where solder each wire, try with a tester in the continuity mode, and test between the each part of the tip and the three holes. Greetings!
Anderson Barreto - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
great instruction - any for repair of cable with microphone ? and even a flat cable ?
LiveVest - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 20
crwdns2936753:07crwdne2936753:0 157
crwdns2936753:030crwdne2936753:0 815
crwdns2942667:0crwdne2942667:0 130,776
