How to Repair a Christmas Tree Light Wire
  1. How to Repair a Christmas Tree Light Wire, How to Repair a Christmas Tree Light Wire: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the lighting.
  2. How to Repair a Christmas Tree Light Wire: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Repair a Christmas Tree Light Wire: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the wire strippers, split both wires apart approximately one inch.
  3. How to Repair a Christmas Tree Light Wire: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Repair a Christmas Tree Light Wire: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the wire strippers, strip about an inch of insulation off of each wire.
    • Use appropriate wire gauge when stripping. A good practice is to start with large gauge and work your way down.
  4. How to Repair a Christmas Tree Light Wire: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Repair a Christmas Tree Light Wire: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Twist all four copper strands.
    • This will make it easier to work with and help prevent fraying.
  5. How to Repair a Christmas Tree Light Wire: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the heat shrink tubing on the longer end of your wire.
    • Once the heat shrink is on your wire, slide it out of your way. We will address the heat shrink in Step 9.
  6. How to Repair a Christmas Tree Light Wire: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Repair a Christmas Tree Light Wire: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Repair a Christmas Tree Light Wire: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Cross and twist the wires together to create a connection.
    • This helps the wires form a better connection when soldering together.
  7. How to Repair a Christmas Tree Light Wire: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Repair a Christmas Tree Light Wire: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Solder your wires together by applying heat to the bottom of your wires and solder to the top. The solder will melt onto the copper strands solidifying both wires together.
    • Burn and fire hazard. Take appropriate precautions and solder in a well-ventilated area.
    • Pre-heat soldering iron to 325 Fahrenheit.
  8. How to Repair a Christmas Tree Light Wire: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use electrical tape to wrap the soldered wires.
    • This will prevent both wires from contacting each other.
  9. How to Repair a Christmas Tree Light Wire: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the heat shrink over the soldered wires.
  10. How to Repair a Christmas Tree Light Wire: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your heat source to apply heat to the heat shrink.
    • Apply heat from heat appliance half an inch away from heat shrink.
  11. How to Repair a Christmas Tree Light Wire: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Repair a Christmas Tree Light Wire: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Connect your Christmas tree plug into the outlet.
You've completed soldering and properly covered any exposed wires being worked on. Connect your cable to an electrical outlet; you're Christmas tree is ready to light once again.
Javi Becerra
crwdns2935283:003/01/23crwdne2935283:0
199 crwdns2915208:0crwdne2915208:0
Austin Community College, Team 60-3, Watkins Spring 2023 crwdns2935289:0Austin Community College, Team 60-3, Watkins Spring 2023crwdne2935289:0
AUSTINCC-WATKINS-S23S60G3
You can also offset the lengths of the twin wires so the joints aren't next to each other for more protection from a short.
pdb - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 1,368
