How to Repair a Broken Speaker Cable on a Harman Kardon CN-04N567-4822
  1. How to Repair a Broken Speaker Cable on a Harman Kardon CN-04N567-4822, How to Repair a Broken Speaker Cable on a Harman Kardon CN-04N567-4822: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Repair a Broken Speaker Cable on a Harman Kardon CN-04N567-4822, How to Repair a Broken Speaker Cable on a Harman Kardon CN-04N567-4822: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Repair a Broken Speaker Cable on a Harman Kardon CN-04N567-4822, How to Repair a Broken Speaker Cable on a Harman Kardon CN-04N567-4822: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to pull the top of the speaker grill away from the speaker enclosure.
    • Pull the bottom of the grill away from the speaker enclosure and then completely remove the grill.
    • Four posts attach the grill assembly to the front of speaker enclosure. These posts are located on the back side of the grill assembly.
  2. How to Repair a Broken Speaker Cable on a Harman Kardon CN-04N567-4822: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Repair a Broken Speaker Cable on a Harman Kardon CN-04N567-4822: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the top two 9.5 mm Phillips #1 screws from the speaker.
    • Remove the two 9.5 mm Phillips #1 screws located below the speaker screws.
    • Slowly work your way around the seam until the two parts of the enclosure are free.
    • More speaker cable slack may be achieved by pulling additional cable through the rear of the case.
  3. How to Repair a Broken Speaker Cable on a Harman Kardon CN-04N567-4822: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Repair a Broken Speaker Cable on a Harman Kardon CN-04N567-4822: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Inspect both sides of the printed circuit board (PCB) for any raised traces, off-colored areas, or loose components.
    • This step is to avoid making a mechanical repair (re-soldering the wires to the PCB) on a piece of equipment that also has obvious electrical or mechanical issues.
  4. How to Repair a Broken Speaker Cable on a Harman Kardon CN-04N567-4822: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use desoldering braid and a soldering iron to wick away the old solder and wire remnants from the solder pads and through-holes.
    • Do not leave solder bridges across the pads as this will cause functional issues.
  5. How to Repair a Broken Speaker Cable on a Harman Kardon CN-04N567-4822: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Repair a Broken Speaker Cable on a Harman Kardon CN-04N567-4822: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use wire strippers to remove a small section of insulation from the wires.
    • Use a soldering iron and solder to tin the wires. This prevents the strands from fraying.
  6. How to Repair a Broken Speaker Cable on a Harman Kardon CN-04N567-4822: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Repair a Broken Speaker Cable on a Harman Kardon CN-04N567-4822: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the yellow wire into the through-hole marked "R".
    • Insert the bare ground wire into the through-hole marked "G".
    • Insert the white wire into the through-hole marked "L".
  7. How to Repair a Broken Speaker Cable on a Harman Kardon CN-04N567-4822: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the soldering iron to flow solder between each wire and its solder pad.
  8. How to Repair a Broken Speaker Cable on a Harman Kardon CN-04N567-4822: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reassemble the two parts of the enclosure making sure that the PCB-mounted audio jacks are lined up with the mating holes of the rear enclosure.
    • Route the cable inside the enclosure to avoid stressing the solder joints.
crwdns2935229:08crwdne2935229:0
Ken Gage
crwdns2935283:006/09/16crwdne2935283:0
306 crwdns2915208:0crwdne2915208:0
Texas Tech, Team 3-1, Rauch SU 2016 crwdns2935289:0Texas Tech, Team 3-1, Rauch SU 2016crwdne2935289:0
TTU-RAUCH-SU16S3G1
crwdns2936753:030crwdne2936753:0 54
crwdns2942667:0crwdne2942667:0 4,367
