How to Repair a Broken Barbie Doll Neck
  1. How to Repair a Broken Barbie Doll Neck, How to Repair a Broken Barbie Doll Neck: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Soak Barbie Head in hot water for 3-5 minutes.
  2. How to Repair a Broken Barbie Doll Neck: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Repair a Broken Barbie Doll Neck: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the Barbie head from hot water and immediately pinch/squeeze the head to widen the neck hole.
    • With your available hand, use the tweezers/long nose pliers to gently remove the neck joint from inside the head by pulling and carefully wiggling the neck joint side to side.
  3. How to Repair a Broken Barbie Doll Neck: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Repair a Broken Barbie Doll Neck: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the neck joint is free, place the ball/round end of the joint into the neck.
    • The neck joint may look different but it will always have the ball end inside the neck. If there are two ball ends then it will be the larger ball end.
  4. How to Repair a Broken Barbie Doll Neck: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Put on gloves and a mask then set up acrylic nail set supplies (acrylic liquid, acrylic powder, brush).
    • Pour a small amount of acrylic liquid into the glass dish.
  5. How to Repair a Broken Barbie Doll Neck: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Repair a Broken Barbie Doll Neck: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Repair a Broken Barbie Doll Neck: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Dip the brush into the acrylic liquid then immediately dip it into the acrylic powder.
    • Slowly apply the acrylic to the missing section on the neck a little at a time.
    • Caution: Be sure to work in a well ventilated room
    • Make sure the acrylic is not runny when applying.
    • Before it cools, you may use a toothpick to adjust and shape the acrylic to match the curvature of the neck (optional).
  6. How to Repair a Broken Barbie Doll Neck: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Repair a Broken Barbie Doll Neck: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Repair a Broken Barbie Doll Neck: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Let cool for 2-3 minutes then wiggle the neck peg around gently and slightly until it disconnects from the acrylic and moves with ease.
    • After a couple more minutes, wiggle the neck peg again.
  7. How to Repair a Broken Barbie Doll Neck: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Repair a Broken Barbie Doll Neck: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Repair a Broken Barbie Doll Neck: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the acrylic dries, soak the head in hot water again for 3-5 minutes.
    • Pinch/squeeze the base of the head and gently reapply the Barbie head to the top of the neck peg that is now attached to the neck base.
The Barbie is now complete and is able to move its head normally once more!
Lexi
crwdns2935283:001/22/25crwdne2935283:0
145 crwdns2915208:0crwdne2915208:0
Rose State College, Team 2-6, Kirkman Spring 2025 crwdns2935289:0Rose State College, Team 2-6, Kirkman Spring 2025crwdne2935289:0
ROSE-KIRKMAN-S25S2G6
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 149
