This guide will show the user how to take apart the junction box and clean any corrosion in your 2010-2014 Ford Mustang. If you have corrosion this can cause electrical problems.
Pull hood release tab inside the car.
Disconnect the positive side battery cable from the battery with an 8mm wrench.
Place the positive side battery cable on a non-conductive surface, like a towel.
Pull off the passenger side kick-plate panel by pulling on the unconnected end with moderate force.
Remove the six connectors from the junction box. The large connector at the bottom of the junction box will be removed during step 6.
Unhook nearby wires from hangers on junction box by using a flat head screwdriver.
Use the screwdriver to push on the hanger tab and then pull the wire connector forward.
Using a 10 mm socket wrench, remove the mounting nut from bottom of junction box.
Slightly lift the junction box and then remove the final large connector on the bottom of the junction box.
Lift the junction box 90 degrees to unhook the junction box from the fender wall and then pull the junction box completely out.
Inspect all connectors for corrosion to indicate where the junction box needs cleaning.
Place the junction box in a clean ventilated area and on a flat surface.
Remove the fuse panel cover.
Using the fuse puller located in the fuse cover, remove all of the small fuses.
Remove the larger fuse and relay by hand using moderate force.
Use a flat head screwdriver or plastic opening tool to detach the small tabs on the junction box.
Remove the top plastic cover and the control boards from the bottom cover.
Examine the top junction box cover for any corrosion or burn spots.
If no burns are found, spray contact cleaner on corroded areas. If there are burns on the control board, the junction box can not be saved.
Before the contact cleaner dries, scrub the corroded components on the control board with a tooth brush.
Scrub the control board cover with a wire or soft brush as needed.
Spray a moderate amount of contact cleaner on all corroded wire connectors.
Before the contact cleaner dries, use a wire brush or soft brush to clean off the corrosion.
Allow all components to dry for three or more hours.
crwdns2935229:09crwdne2935229:0
crwdns2944067:06crwdne2944067:0
Great job with this guide.
Fantastic, with good photos. My 2011 Mustang Tire Pressure Monitor system is putting up error message "Tire Pressure Sensor Fault" but the sending units in the wheels/tires are new and have been tested twice as working correctly and the TPMS system was reset, but after 30 minutes of driving the warning light flashes and the error message appears. Tire pressure is exactly what it is supposed to be. I asked the local Ford dealer what they charged to determine what is wrong with the system.......$200!.. No thanks. Then I found out the Smart Junction Box (AKA Body Control Module) is $432 from this dealer, but can be had new from other Ford dealers for as low as $290. However I strongly suspect that the only problem is a bad electrical connection, so I will follow this guide to clean the contacts and I bet that is the cure. I will post an update after I clean the contacts and verify there are no signs of overheating or failed components and if the problem is fixed.
did you try the fix?
My 2012 mustang GT 5.0 just went dead battery good lights still come on but once I turn the key forward no lights on the dash window don’t go up I’m Definitely about to go outside side and try this what I have to lose thank you I will up date late
Try replacing relay starter fuse on junction box some simple I had that problem with my 2010 gt
