This guide will be helpful for repairing your faulty wires if the troubleshooting page recommends that you replace them. This is a necessary step when you have determined no other way to repair your current wires. Be wary of accidentally damaging other parts of the device when replacing wires.
Begin by removing the two main black face plates on either end of the speaker tube using a Phillips head PH1 screwdriver fitting to remove a total of four screws.
2 on top on of either end of the speaker, 2 on bottom of either end of the speaker.
To do this, use a metal spudger as a wedge and insert it in the center and outer edge of the two mesh pieces to remove them exposing screws.
Use a PH1 size Phillips head screwdriver to remove the four 0.7 cm screws.
Pull out the red interface plate to expose the wires that were previously hidden between the black faceplate and red interface plate.
Again look for signs of wire damage.
Look into the back of the red interface plate and locate the bottom of the motherboard.
On the bottom of the motherboard, locate the black and red wire pair connected to the plastic red socket and remove the white insert from this socket.
To repair a wire connection, use wire strippers to cut away the wire portion until no visible damage remains.
Again, use the wire strippers to strip back a small amount of the rubber coating on the wire. Therefore exposing a small amount of bare wire.
Assuming you have enough wire length to spare, insert the bare wire into a wire butt connector so it just passes the nub on one end.
Then use a wire crimping tool to crimp the the butt connector, therefore making a solid contact connection.
Repeat for the loose wire into the other end of the same wire butt connector.
Just one wire is not going to do it. A red wire
Was loose before I opened the speaker and I can't see where it was attached to. Why don't you put a pic of the circuit board so people can fix your cheap ass connections.
