This guide demonstrate how to repair peeling or damaged veneers on cabinets. This technique help you avoid costly replacements. While the process is demonstrated on a cabinet, the process can be modified to fix the veneer on a wide variety of furniture.
Wipe down the damaged surface with a damp cloth to remove any dust and debris.
Allow the area to fully dry before continuing.
Apply a thin layer of rubber cement between the peeled veneer and plywood.
Press the veneer down from the center in an outwards motion to adhere the veneer to the plywood.
Place your brace over the damaged area and keep pressure on it.
Maintaining pressure on the brace, apply the first clamp around the pieces.
Make sure the clamp is holding the brace flush, then tighten it into place.
Once all clamps are secured, refer to the rubber cement label to determine the approximate drying time.
After the rubber cement is fully dry, remove the clamps and the brace.
Enjoy your renewed veneer!
