How to Repair LED Strip Lights
  1. How to Repair LED Strip Lights, How to Repair LED Strip Lights: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Find the spot where the lights stop working and where there are four connections labeled in descending order, "12V, R, G, B" with a scissor "cut here" marking and a copper colored backing.
    So do you have to cut both parts the metal area and the copper area of the strip
    Dalvin Nash - crwdns2934203:0crwdne2934203:0
  2. How to Repair LED Strip Lights: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With a scissor, cut along the "cut here" line, separating the faulty strip from the working strip.
  3. How to Repair LED Strip Lights: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Align the new strip next to the working strip and keep them steady. Look at the four connections like a mirror image. R to R, G to G, and so on and so forth. Apply solder in any order for all four connections. Make sure solder is secured and steady.
  4. How to Repair LED Strip Lights: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the four connections are soldered securely, plug in the strip and turn the lights to all three colors to ensure that the connections are steady. Now you may place the lights where so desired.
    • If the strips had an adhesive backing, some new adhesive material may be required.
    That poor strip looks butchered no no no your strip shouldn’t look charred when your done <…>
    Brandon Wallns - crwdns2934203:0crwdne2934203:0
    Great guide and then BAAM! horrible soldering 😄
    But no worries, keep it clean, have precision and don't let the connections touch eachother.
    Also be aware that faulty soldering can be a fire hazard so keep that in mind whenever you use the LED strip afterwards.
    Magnusson - crwdns2934203:0crwdne2934203:0
A solder and soldering iron are fairly common and easy to acquire at a hardware store. Extra length of lights may be left over from initial use, use these first before buying more in order to lower costs; be sure you only cut the lights for repair where these 4 pads are they are likely marked by a dotted line across them, this is also where you'll solder them together. In order to put the lights back where they originally were, some form of an adhesive agent may need to be utilized. On the rear side of connection spot you can glue a small piece of cardboard to hold them together.
crwdns2935229:015crwdne2935229:0
Jacob
crwdns2935283:003/12/21crwdne2935283:0
424 crwdns2915208:0crwdne2915208:0
University of Memphis, Team S52-G14, Kim Spring 2021 crwdns2935289:0University of Memphis, Team S52-G14, Kim Spring 2021crwdne2935289:0
UM-KIM-S21S52G14
I dont know why this tutorial is rated as difficult, it really isnt.
Andrea Sherville - crwdns2934203:0crwdne2934203:0
Totally agree with Andrea Sherville. This has to be rated easy-moderate as this really isn’t difficult at all.
S Lee - crwdns2934203:0crwdne2934203:0
Huh, I needed this exact guide. That's nuts.
FarmYard Gaming - crwdns2934203:0crwdne2934203:0
El autor dice: Si la soldadura no es una habilidad con la que estés familiarizado, primero debes consultar otra guía sobre los conceptos básicos de la soldadura. Se llama [guía|750|“Cómo soldar y desoldar conexiones”.] el autor no leyó esa guia la soldadura del paso 4 parecen cagadas de paloma
eamig - crwdns2934203:0crwdne2934203:0
hafe of the the strip doesn't lit up
albert sesay - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 82
crwdns2936753:07crwdne2936753:0 476
crwdns2936753:030crwdne2936753:0 2,162
crwdns2942667:0crwdne2942667:0 138,822
