Metal waist chains are belts worn as fashion accessories.
Sometimes chain links can open due to warping caused by repeated wear and tear, making the chain links to come apart. Instead of throwing your waist chain away, this quick and easy guide can help you repair it so you can keep wearing it.
This repair requires inspecting small parts. If you have a harder time with holding small parts or seeing small parts, you might want to have somebody with smaller hands or better eyesight assist you.
Before beginning this repair, ensure that you know how to hold the pliers comfortably in your hand.
Hold one plier in each hand and grip the desired ring on the end of the waist chain.
At the same time, move one plier towards you and one plier away from you in order to open up the ring.
Link the end of the broken chain segment to the open ring.
Use the pliers to grip the open ring.
Move the pliers in the opposite direction from which you opened it.
Inspect the waist chain again and look for other areas that need to be repaired.
Repeat the same process for any other areas of breakage.
Once the whole waist chain is reconnected, check to make sure that there are no gaps in the chain links.
