How to Repair A Broken Metal Waist Chain
  1. How to Repair A Broken Metal Waist Chain, How to Repair A Broken Metal Waist Chain: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Hold one plier in each hand and grip the desired ring on the end of the waist chain.
    • Any two pliers can be used for this repair. However, we recommend needle nose pliers since you will be working with small chain links.
  2. How to Repair A Broken Metal Waist Chain: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Repair A Broken Metal Waist Chain: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Repair A Broken Metal Waist Chain: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • At the same time, move one plier towards you and one plier away from you in order to open up the ring.
    • Make sure your grip on the ring is sturdy. Your pliers can easily slip off due to how small the ring is.
    • Bend the ring slightly by opening it just enough for the other ring to link. Do not open it all the way since it will be difficult to close.
  3. How to Repair A Broken Metal Waist Chain: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Repair A Broken Metal Waist Chain: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Link the end of the broken chain segment to the open ring.
  4. How to Repair A Broken Metal Waist Chain: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Repair A Broken Metal Waist Chain: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Repair A Broken Metal Waist Chain: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the pliers to grip the open ring.
    • Move the pliers in the opposite direction from which you opened it.
    • You should now have a closed ring.
    • Make sure the ring is closed all the way. If it is not, this can result in the waist chain breaking again.
  5. How to Repair A Broken Metal Waist Chain: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Inspect the waist chain again and look for other areas that need to be repaired.
    • Repeat the same process for any other areas of breakage.
  6. How to Repair A Broken Metal Waist Chain: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the whole waist chain is reconnected, check to make sure that there are no gaps in the chain links.
    • If you can pull on the chain without it coming apart, you have successfully repaired the belt!
Jillian Wong
crwdns2935283:005/12/25crwdne2935283:0
133 crwdns2915208:0crwdne2915208:0
UC Davis, Team 2-3, Whithaus Spring 2025 crwdns2935289:0UC Davis, Team 2-3, Whithaus Spring 2025crwdne2935289:0
UCD-WHITHAUS-S25S2G3
crwdns2942667:0crwdne2942667:0 103
