How to Repair A Broken Hip In A Plastic Doll
  1. How to Repair A Broken Hip In A Plastic Doll, How to Repair A Broken Hip In A Plastic Doll: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Repair A Broken Hip In A Plastic Doll, How to Repair A Broken Hip In A Plastic Doll: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Determine where your doll is broken: is it at the knee? Hip? Arm?
    • If it’s broken at the knee, as marked in the second photo, unfortunately this guide will not help as it is a different kind of joint.
  2. How to Repair A Broken Hip In A Plastic Doll: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Repair A Broken Hip In A Plastic Doll: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If the ball is still inside the leg, remove it with pliers.
  3. How to Repair A Broken Hip In A Plastic Doll: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Hold one of the sewing pins with the pliers and heat the sewing pin with a lighter.
    • Do not leave fire unattended. The metal will be hot, so please don't touch it with your bare skin.
  4. How to Repair A Broken Hip In A Plastic Doll: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the hot sewing needle, make a small hole in the center of the broken off ball. Make sure the needle is straight.
    • This may take a few attempts and a few needles.
    • Heating up the plastic will result in some fumes. Perform this step in a well ventilated area.
  5. How to Repair A Broken Hip In A Plastic Doll: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Hold one of the sewing pins with the pliers and heat the sewing pin with a lighter. (This is a repeat of Step 3.)
  6. How to Repair A Broken Hip In A Plastic Doll: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Repair A Broken Hip In A Plastic Doll: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the hot sewing needle, make a small hole in the peg of the hip. Make sure the needle is straight. Leave the pin inside.
  7. How to Repair A Broken Hip In A Plastic Doll: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Repair A Broken Hip In A Plastic Doll: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the pin from the broken off ball joint with a pair of pliers.
  8. How to Repair A Broken Hip In A Plastic Doll: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Repair A Broken Hip In A Plastic Doll: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the pliers, cut the pin in the hip section to the appropriate length to fit into the hole made from Step 6.
    • Test the needle length by fitting the ball joint pieces together. The needle should be completely covered.
    • The needle will go flying when you cut it, so direct it away from your face and other precious objects.
  9. How to Repair A Broken Hip In A Plastic Doll: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Optional: remove any excess burnt plastic from the ball joint.
  10. How to Repair A Broken Hip In A Plastic Doll: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Repair A Broken Hip In A Plastic Doll: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Repair A Broken Hip In A Plastic Doll: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the pin from the hip and apply super glue to the end.
    • Insert the pin back into the hole.
    • When you reinsert the pin, some glue may come out. Leave it for Step 11.
  11. How to Repair A Broken Hip In A Plastic Doll: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push the ball onto the pin. Press together for 1 minute to set the glue.
    • The glue will set in 1 minute but it will take 24 hours to fully cure.
  12. How to Repair A Broken Hip In A Plastic Doll: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply glue around the seam for extra reinforcement.
  13. How to Repair A Broken Hip In A Plastic Doll: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Repair A Broken Hip In A Plastic Doll: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now with the ball joint secured into the pelvis, carefully pop the leg back into the hip.
    • The doll's leg should now move as normal!
To reassemble your device, follow these instructions in order.
Lee Brunkhardt
crwdns2935283:001/31/23crwdne2935283:0
232 crwdns2915208:0crwdne2915208:0
UC Davis, Team 3-1, Andersen Winter 2023 crwdns2935289:0UC Davis, Team 3-1, Andersen Winter 2023crwdne2935289:0
UCD-ANDERSEN-W23S3G1
But is there a way you can attach the Barbie doll leg by just pushing the leg instead of doing all of that?
Amalachukwu - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 87
crwdns2942667:0crwdne2942667:0 2,812
