How to Remove the Expansion Bay in your Framework Laptop 16"
  1. How to Remove the Expansion Bay in your Framework Laptop 16", Before you begin: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Remove the Expansion Bay in your Framework Laptop 16", Before you begin: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug all cables and fully shut down your laptop.
    • If your repair requires a spudger, a T5 Torx, or a Phillips screwdriver, you can use the included Framework screwdriver. Whichever works best for you!
  2. How to Remove the Expansion Bay in your Framework Laptop 16", Remove the touchpad spacers: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Remove the Expansion Bay in your Framework Laptop 16", Remove the touchpad spacers: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Remove the Expansion Bay in your Framework Laptop 16", Remove the touchpad spacers: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to slide the touchpad spacer toward the bottom edge of the laptop and unclip it.
    • If you're having trouble, check if the corresponding Input Module latch is properly unlocked.
    • Lift the touchpad spacer off the laptop and remove it.
  3. How to Remove the Expansion Bay in your Framework Laptop 16": crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Repeat the same procedure for the other touchpad spacer.
  4. How to Remove the Expansion Bay in your Framework Laptop 16", Remove the touchpad: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Remove the Expansion Bay in your Framework Laptop 16", Remove the touchpad: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Remove the Expansion Bay in your Framework Laptop 16", Remove the touchpad: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to slide the touchpad toward the bottom edge of the laptop and disconnect it.
    • If you're having trouble, check if the Input Module latches are properly unlocked.
    • Lift the touchpad and remove it.
    • During reassembly, perform the following:
    • Place the touchpad flat on its cutout so its clips are properly aligned.
    • Press the touchpad down and slide it into place so it lines up evenly with the bottom edge of the laptop.
  5. How to Remove the Expansion Bay in your Framework Laptop 16", Remove the keyboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Remove the Expansion Bay in your Framework Laptop 16", Remove the keyboard: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Remove the Expansion Bay in your Framework Laptop 16", Remove the keyboard: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The keyboard is held in place with strong magnets. Apply gradually increasing force to avoid having the keyboard violently eject.
    • Grip the two pull tabs along the bottom of the keyboard.
    • Lift the pull tabs until the keyboard magnets release.
    • Remove the keyboard.
    • During reassembly, make sure the keyboard is seated properly on its alignment pegs and sits evenly with the edges of the laptop.
  6. How to Remove the Expansion Bay in your Framework Laptop 16", Remove the numpad: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Remove the Expansion Bay in your Framework Laptop 16", Remove the numpad: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Remove the Expansion Bay in your Framework Laptop 16", Remove the numpad: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The numpad is held in place with strong magnets. Apply gradually increasing force to avoid having the numpad violently eject.
    • Grip the pull tab at the bottom of the numpad.
    • Lift the pull tab until the numpad magnets release.
    • Remove the numpad.
    • During reassembly, make sure the numpad is seated properly on its alignment pegs and sits flush with the edges of the laptop.
  7. How to Remove the Expansion Bay in your Framework Laptop 16", Lift the interposer door: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Remove the Expansion Bay in your Framework Laptop 16", Lift the interposer door: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the interposer door by its black pull tab and let it rest upright.
  8. How to Remove the Expansion Bay in your Framework Laptop 16", Loosen the interposer screws: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Remove the Expansion Bay in your Framework Laptop 16", Loosen the interposer screws: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Remove the Expansion Bay in your Framework Laptop 16", Loosen the interposer screws: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If you have the graphics module installed, your interposer will have four screws. Otherwise, you'll have three screws.
    • Lift the pull tab on the interposer and let it rest vertically to access all of its screws.
    • Use a T5 Torx screwdriver to loosen the three captive screws securing the interposer.
    • If you have the graphics module, use a T5 Torx screwdriver to loosen the four captive screws securing the interposer.
  9. How to Remove the Expansion Bay in your Framework Laptop 16", Remove the interposer: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Remove the Expansion Bay in your Framework Laptop 16", Remove the interposer: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the interposer by its pull tab and remove it.
  10. How to Remove the Expansion Bay in your Framework Laptop 16", Loosen the expansion bay screws: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Remove the Expansion Bay in your Framework Laptop 16", Loosen the expansion bay screws: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T5 Torx screwdriver to loosen the two captive screws securing the expansion bay.
    • Close the interposer door before continuing.
  11. How to Remove the Expansion Bay in your Framework Laptop 16", Remove the expansion bay: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Remove the Expansion Bay in your Framework Laptop 16", Remove the expansion bay: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Remove the Expansion Bay in your Framework Laptop 16", Remove the expansion bay: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Close your laptop and flip it over.
    • Slide the expansion bay out of the laptop and remove it.
    • The bay should slide out easily. If you feel any resistance, check that the screws holding it in place are fully loosened.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Alex Diaz-Kokaisl
crwdns2935283:001/16/22crwdne2935283:0
169,220 crwdns2915208:0crwdne2915208:0
crwdns2935297:0769crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,541crwdne2935297:0
crwdns2936753:030crwdne2936753:0 41
crwdns2942667:0crwdne2942667:0 559
