This guide is for anyone who has a scratched CD that is not working any more. In most cases this relatively quick and easy method has worked for me, and hopefully it works for you too.
Identify any scratches.
Take the CD to the sink.
Wash with lukewarm water to remove any dust or dirt.
Let the CD air dry, or dry with towel.
Take the toothpaste, and apply it to your index finger.
Rinse the toothpaste in lukewarm water and apply to the CD.
Rub toothpaste in a circular motion from the center to the outer edge.
Add multiple layers of toothpaste to cover all of the scratches.
Let the CD sit for 2 to 3 minutes.
Unless I’m missing something, If you’re using toothpaste to polish the scratches out of a CD, there’s no need to let it sit with the paste on it. It’s the circular motion moving the aggregate in the paste that is removing the scratches.
Ik ben het hiermee eens. Wat zou het nut zijn om de tandpasta een tijdje op de CD te laten rusten?
Rinse off the toothpaste with lukewarm water.
Let the CD air dry, or dry with a non-linen towel.
Inspect your disk.
If your disk still has scratches, repeat the process.
crwdns2935229:044crwdne2935229:0
crwdns2947412:05crwdne2947412:0
Works great!
thank youuuuuuuuu
Funziona anche con i DVD di film e videogiochi questo procedimento? Oppure è solo specifico per i CD?
It did not work for me
Me Funciono muy bien, gracias!
