How to Remove scratches from a CD
  1. How to Remove scratches from a CD, How to Remove scratches from a CD: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Identify any scratches.
    • Some scratches may be too deep to be removed. In this case, this method may not work.
  2. How to Remove scratches from a CD: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Remove scratches from a CD: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Take the CD to the sink.
    • Wash with lukewarm water to remove any dust or dirt.
  3. How to Remove scratches from a CD: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Let the CD air dry, or dry with towel.
    • Use a non-linen towel or your CD will need to be washed again.
  4. How to Remove scratches from a CD: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Remove scratches from a CD: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Remove scratches from a CD: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take the toothpaste, and apply it to your index finger.
    • Rinse the toothpaste in lukewarm water and apply to the CD.
    • Rub toothpaste in a circular motion from the center to the outer edge.
    • Add multiple layers of toothpaste to cover all of the scratches.
    • Use a white toothpaste, not a gel. Gels containing little beads may cause more damage to the CD.
  5. How to Remove scratches from a CD: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Let the CD sit for 2 to 3 minutes.
    Unless I’m missing something, If you’re using toothpaste to polish the scratches out of a CD, there’s no need to let it sit with the paste on it. It’s the circular motion moving the aggregate in the paste that is removing the scratches.
    Jimmy Hoffa - crwdns2934203:0crwdne2934203:0
    Ik ben het hiermee eens. Wat zou het nut zijn om de tandpasta een tijdje op de CD te laten rusten?
    Roy Damman - crwdns2934203:0crwdne2934203:0
  6. How to Remove scratches from a CD: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Rinse off the toothpaste with lukewarm water.
  7. How to Remove scratches from a CD: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Let the CD air dry, or dry with a non-linen towel.
  8. How to Remove scratches from a CD: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Inspect your disk.
    • If your disk still has scratches, repeat the process.
    • You could also try to burn the disk onto another disk if the disk is lagging.
crwdns2935229:044crwdne2935229:0
Nick Jones
crwdns2935283:009/29/15crwdne2935283:0
1.485 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 14-4, Green Fall 2015 crwdns2935289:0Cal Poly, Team 14-4, Green Fall 2015crwdne2935289:0
CPSU-GREEN-F15S14G4
crwdns2935297:017crwdne2935297:0
crwdns2947412:05crwdne2947412:0
Funziona anche con i DVD di film e videogiochi questo procedimento? Oppure è solo specifico per i CD?
Francesco Pepe - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 46
crwdns2936753:07crwdne2936753:0 333
crwdns2936753:030crwdne2936753:0 1,142
crwdns2942667:0crwdne2942667:0 73,669
