How to Remove and Replace Caulk in a Bathtub
  1. How to Remove and Replace Caulk in a Bathtub, Replacing Caulk in Bathtub: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove current caulk from bathtub using a sharp tool such as a knife or utility tool. Test it first in a small area to not scrape the bathtub.
  2. How to Remove and Replace Caulk in a Bathtub: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Clean the surface and mold from the area with a putty knife. Excess caulk can be removed with a combination of liquid caulk removal. Remove the rest of the residue with a knife.
  3. How to Remove and Replace Caulk in a Bathtub: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Dry the area well to prevent mold from forming and it let it dry overnight before continuing the next step.
  4. How to Remove and Replace Caulk in a Bathtub: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Remove and Replace Caulk in a Bathtub: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Tape around the area that is going to be caulked. Place the tape 1/8 inch on either side of the seam that is going to be caulked. The tape keeps the caulk in a smooth line.
  5. How to Remove and Replace Caulk in a Bathtub: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Remove and Replace Caulk in a Bathtub: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Trim the opening of the caulk from the caulk gun to 1/8 an inch and use it a 45-degree angle and make sure it is the same size as the area between the tape.
  6. How to Remove and Replace Caulk in a Bathtub: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Remove and Replace Caulk in a Bathtub: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Load the caulk gun and use a steady pressure along the space between the tape as you move across it. An even pace is needed; if it’s too slow the caulk will pile up, and if it’s too fast it will break easily.
  7. How to Remove and Replace Caulk in a Bathtub: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Smooth out the line of caulk with your finger.
  8. How to Remove and Replace Caulk in a Bathtub: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Remove and Replace Caulk in a Bathtub: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove tape and fix any blemishes.
If you are how unhappy how the caulk turned out; don’t worry you can just do the following the steps again as there is no permanent damage done with caulking.
Ian Johnson
crwdns2935283:003/26/20crwdne2935283:0
167 crwdns2915208:0crwdne2915208:0
University of Memphis, Team S5-G13, Willis Spring 2020 crwdns2935289:0University of Memphis, Team S5-G13, Willis Spring 2020crwdne2935289:0
UM-WILLIS-S20S5G13
crwdns2936753:030crwdne2936753:0 82
crwdns2942667:0crwdne2942667:0 3,199
