In this tutorial, we'll cover every step of how to take out and clean the float switch from your Kenmore 575-0 dishwasher. A malfunctioning float switch can lead to water-related problems, disrupting the dishwasher's function and potentially causing costly damage.
This manual is available to help if the float assembly on your Kenmore 575-0 dishwasher needs cleaning or maintenance. This guide focuses on simple methods for removing and cleaning your dishwasher's float assembly, in contrast to certain techniques that require complicated steps.
To easily access the float assembly, open the dishwasher and carefully slide out the lower rack.
Use a Phillips #1 screwdriver to remove two 5 mm screws from the ends of the bottom cover of the dishwasher.
Remove the bottom cover.
Loosen the single 5 mm screw at the base of the dishwasher that secures the float switch in place using a Phillips #1 screwdriver.
Find the float assembly positioned near the front, underneath the lower rack.
Carefully press on top of the float assembly and then release to elevate the float.
Reconnect the float assembly to its initial position and fasten it securely. Verify that it moves smoothly and without obstruction.
Now that the float switch is clean, reinsert the lower rack.
Reassemble the base of the dishwasher.
