Daily wear and tear from groceries, luggage and sporting equipment can result in scratches and marks on a cars interior. Scratches on an interior surface can look ugly and can also depreciate your cars value over time. No driver wants to see their vehicle with imperfections, but luckily there are things we can do to reduce and remove them. These necessary steps are easy repairs that will not only make your car look better but last longer. In order to remove scratches from a cars interior, you can either buy a specialized kit containing everything you need or use a combination of sanding, painting and heating to remove it by hand.
Clean the area around the scratch with the interior cleaner.
Using the heat gun, gently apply heat to the plastic until it begins to soften.
Apply the grain pad to the intended area using light pressure.
Dove si acquistano le "grain texture", che nella descrizione viene chiamata paglietta?
Use a super- fine grain sandpaper to sand out the area, making it smooth and authentic looking.
Clean and dry the area again using the same method as in step 1 (the interior cleaner) and you're done!
By following these steps you will be able to remove scratches from your cars interior.
what brand of grain pads do you recommend? having a difficult time finding them onlinw
Any luck finding “grain texture” pads?
