How to Reconnect an Alligator Clamp to a Battery Charging Cable
  1. How to Reconnect an Alligator Clamp to a Battery Charging Cable, How to Reconnect an Alligator Clamp to a Battery Charging Cable: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Reconnect an Alligator Clamp to a Battery Charging Cable, How to Reconnect an Alligator Clamp to a Battery Charging Cable: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Determine which handle of the alligator clamp originally secured the charging cable. (The tabs will be pressed down and there will most likely be remnants of copper strands)
    • Slide the rubber grip off of the handle which did NOT originally secure the charging cable.
  2. How to Reconnect an Alligator Clamp to a Battery Charging Cable: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If you use a knife, be wary of slicing your thumb if the sharp edge is faced towards you. (Use Wire Strippers if you have them)
    • Remove about an inch of insulation from the cable using a knife, a razor blade, or wire strippers.
  3. How to Reconnect an Alligator Clamp to a Battery Charging Cable: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Clip the excess frayed copper strands from the cable using the wire cutters.
  4. How to Reconnect an Alligator Clamp to a Battery Charging Cable: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Reconnect an Alligator Clamp to a Battery Charging Cable: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Reconnect an Alligator Clamp to a Battery Charging Cable: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the rubber grip over the wire. You may not be able to to so after the wire is crimped.
    • Place the cable in the unused side of the alligator clamp.
    • Place the exposed copper strands in between these two tabs.
    • Make sure that the insulation covers the full area between these two tabs.
  5. How to Reconnect an Alligator Clamp to a Battery Charging Cable: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The harder the tabs are pressed onto the cable, the more secure the connection will be.
    • Use the vice grips to press down all four tabs onto the cable.
  6. How to Reconnect an Alligator Clamp to a Battery Charging Cable: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the rubber grip back onto the handle.
Now plug in the Battery Charger to test for continuity from the cable to the clamp, by charging a battery.
Derek Moore
crwdns2935283:010/06/16crwdne2935283:0
University of Memphis, Team 4-4, Baddour Fall 2016 crwdns2935289:0University of Memphis, Team 4-4, Baddour Fall 2016crwdne2935289:0
UM-BADDOUR-F16S4G4
crwdns2942667:0crwdne2942667:0 4,364
