After vaping on the cotton and coils currently in use, they will start to get a burnt taste. This is when the cotton and coils need to be replaced (rebuilt). If this is not done every other week or so, you will not get as much out of your vape and could ultimately end up burning the back of your throat. The guide will teach you how to rebuild the cotton and coils so this can be avoided.
Turn Vape off by pressing the largest button 5 times in row quickly.
Cut two, 8 inch pieces of 24 gauge kanthal wire with the wire cutters.
Hold the screwdriver and the wire end in one hand (non dominant) and the loose end of the wire in the other hand (dominant).
Using the loose end of the wire, wrap 4-8 times (depending on desired ohms) around the screwdriver.
Leave wire wrapped around screwdriver and use fingernails to push the coil down towards base of screwdriver.
Carefully slide the coil off of the screwdriver.
Repeat steps 3-6 with the other piece of wire, making sure to have the same amount of loops in both coils.
Unscrew the top four screws on atomizer without removing them.
Put one end of the coil in an outermost hole on side of screw and other end in one of the inner holes.
Repeat step 10 on other side with other coil.
Tighten the screws completely once coils are in desired position.
Cut wires as close to the posts as possible.
Put the screwdriver through the coil to place the coil in desired position.
Re-insert the batteries and press the large button 5 times quickly to turn the vape on.
Press the biggest button on vape to heat up coils until red hot.
Use tweezers to compress the coils, being careful not to touch the tweezers to the coils while the button is being pressed.
Repeat on other side. Coils are ready when both sides glow red hot at the same time.
Once coils are cooled, tear a cotton strip from the large square and roll it with your hands until you have a tight but long strand.
Take cotton strand and thread through one coil.
Repeat steps 19 & 20 for other coil.
Using the wire cutters, cut cotton approximately ¼ of an inch away from outside of atomizer on each strand.
Tuck cotton underneath coils and into the well of the atomizer using the tweezers.
Juice the cotton and coils completely with your favorite vape juice.
With vapes becoming very popular, this tutorial is very beneficial to those using them. By using this guide, it will save you a drive to your local vape store as well as five to ten dollars every week by building it yourself. As this is practiced more and more, the steps will become easier and more natural. We hope you find this tutorial as helpful to you as it has to us. In the event that the coils do not light up, or no vapor is produced, make sure the wires are properly connected to the screws and that the batteries are charged.
crwdns2935229:016crwdne2935229:0
