How to Patch a Torn Window Screen
  1. How to Patch a Torn Window Screen, How to Patch a Torn Window Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screen from the window frame and place it in your work space.
    • Removing the screen is not necessary but will make the fix easier. You can easily work through this fix with the screen on the frame as long as you can reach the tear from both sides of the screen.
  2. How to Patch a Torn Window Screen: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Patch a Torn Window Screen: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Patch a Torn Window Screen: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • From where the tear ends, measure one inch from the left, right, bottom, and top of the tear.
    • Make note of these measurements as they will be the required size of your patch.
  3. How to Patch a Torn Window Screen: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Patch a Torn Window Screen: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Patch a Torn Window Screen: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Measure your patch using the dimensions determined in step 2.
    • If the patch is larger than said dimensions, mark where you will cut it.
  4. How to Patch a Torn Window Screen: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Patch a Torn Window Screen: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Patch a Torn Window Screen: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use scissors to cut the patch to size.
    • Place your patch over the tear to confirm it extends one inch from every side.
  5. How to Patch a Torn Window Screen: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Patch a Torn Window Screen: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the pliers or tweezers, remove some threads from two opposite sides of the patch.
    • Stop when approximately half an inch of threads are exposed on each side.
  6. How to Patch a Torn Window Screen: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Patch a Torn Window Screen: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Bend the exposed threads 90 degrees on both sides of the patch.
  7. How to Patch a Torn Window Screen: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Patch a Torn Window Screen: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Patch a Torn Window Screen: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use scissors to cut away the frayed sections of the tear.
  8. How to Patch a Torn Window Screen: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Patch a Torn Window Screen: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Patch a Torn Window Screen: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Center the patch over the tear.
    • Press the exposed patch threads through the screen.
    • Try to keep the wires as even as possible. This will make the patch look nicer in the end.
  9. How to Patch a Torn Window Screen: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Patch a Torn Window Screen: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Patch a Torn Window Screen: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently, but firmly, bend the threads back in the direction of the tear to secure the patch.
    • If you are working with a screen still on its frame, place one hand on the side with the patch, while using the other to bend the threads on the other side. This will ensure you do not break your screen by pushing only from one side.
    • Do this for both sides, making sure the patch does not move around when both sides have been bent.
  10. How to Patch a Torn Window Screen: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Patch a Torn Window Screen: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Check that the patch is secure and covers the tear well.
    • If the screen was removed from the frame, reinsert the screen back on the frame.
Your window screen is now patched. Feel free to once again open your window and let the breeze in without any pesky bugs or debris flying through the tear!
Alexis
crwdns2935283:010/26/17crwdne2935283:0
149 crwdns2915208:0crwdne2915208:0
DePaul University, Team S1-G1, Dush Fall 2017 crwdns2935289:0DePaul University, Team S1-G1, Dush Fall 2017crwdne2935289:0
DPU-DUSH-F17S1G1
crwdns2936753:030crwdne2936753:0 141
crwdns2942667:0crwdne2942667:0 2,546
