Repairing a rip in vinyl furniture is a short, simple, and low-cost fit that can be accomplished in the home. Vinyl furniture can rip for a number of reasons, such as a sharp object or a pet scratching the material. It is best to repair a tear as soon as possible to avoid the tear becoming larger.
Clean the damaged area with rubbing alcohol, using a rag, paper towel, or Q-tip.
Cut the backing fabric large enough to cover the tear, approximately half an inch larger around the tear.
Use the spatula tool to insert the backing fabric underneath the tear.
Use the spatula to apply the adhesive to the damaged area.
Let the adhesive dry for approximately four hours.
You may use a hair dryer to speed up the drying process.
Use a Q-tip dipped in rubbing alcohol to buff and blend the area.
Apply light pressure to even out the edges.
Once the adhesive is dry, the furniture is ready for use!
