Use this guide to open your Fitbit Charge 2 for repairs.
Before starting, take your Fitbit Charge 2 off the charger and power it down.
Remove the watch band on both sides.
Heat an iOpener and apply it to the touch screen for two minutes.
crwdns2935267:0crwdne2935267:0iSesamo Opening Tool$9.99
Insert an iSesamo into the gap between the touch screen and the watch assembly on the top left corner.
Slide the iSesamo along the left edge to the bottom left corner.
Slide the iSesamo around the bottom left corner.
Slide it along the edge to the bottom right corner.
Slide the iSesamo around the bottom right corner.
Keep sliding it along the right edge to the top right corner.
Slide the iSesamo around the top right corner.
Slide it along the top edge to the top left corner.
Place the iSesamo under the top left corner.
Pry up the touch screen assembly by twisting the iSesamo sideways to create a gap and unhinge the plastic clips which are holding the screen in place.
Place the iSesamo under the top right corner.
Pry up the touch screen assembly by twisting the iSesamo sideways to create a gap.
Insert a spudger into the gap on the top edge of your Fitbit Charge 2.
Use the spudger to pry up the touch screen assembly.
Carefully fold the touch screen assembly in the direction of the bottom edge.
Opening didn’t go as planned? Ask our Answers community for help.
How do I get the daughterboard out?
