How to Mend a Cactus
  1. How to Mend a Cactus, How to Mend a Cactus: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • First, check the status of your cactus by assessing its dryness. If it feels dried out, an extra step will have to be taken.
  2. How to Mend a Cactus: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If the wound is still fresh, you can proceed to Step 4.
    • If the wound is too dry (feels rough and appears calloused), please proceed to Step 3.
  3. How to Mend a Cactus: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Mend a Cactus: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If the wound seems too dry, use the knife and cut off a thin slice (about a quarter inch) of the dry area of each side of the broken cactus limb.
    • Remember to always wear protective gloves while handling sharp objects!
  4. How to Mend a Cactus: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Mend a Cactus: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Mend a Cactus: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take the broken cactus piece and reattach it carefully to the main body of the cactus.
    • Make sure to align the cambium (center ring of cactus) on each piece properly.
  5. How to Mend a Cactus: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Mend a Cactus: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Mend a Cactus: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the string to tie cactus together. A simple string like embroidery floss works fine.
    • Wind the string around your cactus carefully. Make sure to cross the string over the other, creating a perpendicular line.
    • Repeat this step multiple times until you have wound the string above and below the wound.
    • The string should be tight enough to create support for the cactus.
    I used a toothpick. Stick it in the middle of the top n bottom piece. So far so gd
    Gammy Gno - crwdns2934203:0crwdne2934203:0
  6. How to Mend a Cactus: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Mend a Cactus: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Mend a Cactus: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Alternatively, you can take the broken cactus piece to plant a new cactus!
    • To start the self-propagation process, take the planting pot and fill it with potting soil.
  7. How to Mend a Cactus: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unlike the previous steps, let the broken cactus limb dry out in a shady area in room temperature for about 2 days (or until the end calluses over).
    • Having a calloused piece prevents the cactus from drying out completely and stops plant diseases from entering and infecting the wound.
  8. How to Mend a Cactus: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Mend a Cactus: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the piece is properly calloused, take the cactus and press it gently into the soil. The piece should be resting slightly in the soil and does not have to be buried deep.
    • However, if the broken limb is large, bury the cut end of the limb until it can fully support itself on its own in the soil.
  9. How to Mend a Cactus: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Mend a Cactus: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Regularly water the cactus by misting the soil. Do not over water since this can lead to rot!
    • Most cacti take several months to a year to grow back to its original size, so it will take patience to fully allow your cactus to heal.
    • Cacti grow better in warmer weather, so if you live in a cooler climate, it can take longer than usual.
    • Once it becomes apparent that the cactus is fully healed, remove the string.
    How long it takes until it reattachs?
    Selin Tavashi - crwdns2934203:0crwdne2934203:0
With the appropriate care of your cactus, it should be fully healed and continue to grow!
crwdns2935229:09crwdne2935229:0
Jessica Kim
crwdns2935283:010/26/18crwdne2935283:0
297 crwdns2915208:0crwdne2915208:0
UC Davis, Team S1-G3, Bender Fall 2018 crwdns2935289:0UC Davis, Team S1-G3, Bender Fall 2018crwdne2935289:0
UCD-BENDER-F18S1G3
Thank you , help me a lot! I accidentally cut off my cactus because i though it was rotten after the plant under it rotting from too much water. Here's cactus for you 🎉🌵🌵🌵🎊
Crocaffeine Artlova - crwdns2934203:0crwdne2934203:0
I am looking for a way to obstruct the holes a woodpecker created in a Saguaro Cactus. This plant is 100+ years old and 25+ feet all with three fully developed arms. The solution must be able to withstand 120 degree weather in summer. Any Suggestions?
Al Stoeberl - crwdns2934203:0crwdne2934203:0
Bonjour. Mon cactus hérissé (Austrocylindropuntia subulata ) a deux troncs de 1m90 que je bichonnais depuis 20 ans à basculé dans la nuit. Les deux apex ont été cassés. J'en ai été très triste. Je suis tombé sur ce site et vu qu'il était peut être possible de les "recoller" sur leurs troncs respectifs. J'ai donc découpé des rondelles au cutter, ai repositionné les têtes sur leurs troncs et les ai fixées avec un ruban adhésif de tapisserie en évitant les entrées d'air
.J'ai conservé un tronçon trop long de 15 cm a faire sécher avant de le planter. On verra dans quelques semaines ce qui a réussi et ne manquerai pas d'en faire part sur ce site.
Michel Rabatel - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 11
crwdns2936753:07crwdne2936753:0 63
crwdns2936753:030crwdne2936753:0 350
crwdns2942667:0crwdne2942667:0 39,626
