How to Mend Broken China
Mikkeline Thomsen
crwdns2944107:0crwdnd2944107:0Mikkeline Thomsencrwdnd2944107:0crwdnd2944107:0crwdnd2944107:05crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Yan 13, 2023crwdne2944111:0
2 - 5 crwdns2931253:0crwdne2931253:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
China is delicate and will often break due to daily use and careless handling. This guide will show you how to effectively mend plain, slightly broken china using a clear epoxy filler.
Tip: You can add any pigment to the epoxy, making the cracks less visible and the repair more subtle.
crwdns2944105:0crwdne2944105:0
  1. How to Mend Broken China, How to Mend Broken China: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wipe all broken edges with rubbing alcohol using a paper towel.
    • Do this to eliminate any grease and dirt.
    • Be aware that rubbing alcohol is highly flammable.
    • Be aware of sharp edges throughout this repair.
  2. How to Mend Broken China: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pour epoxy into a smooth-surfaced container.
    • We used the plastic wrapping of the razor, but any container works.
    • Don't use epoxy in a small, confined space.
    • Do not get epoxy near eyes or on skin. Consider using polyethylene or polypropylene gloves.
  3. How to Mend Broken China: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Mix epoxy fluids with a toothpick.
    • The fluid sets in 5 minutes, so you must quickly apply it to the china. You can mix more if the first pour hardens.
  4. How to Mend Broken China: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Mend Broken China: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Apply the epoxy along the edges of the base piece of china and first chipped piece of china using the toothpick.
  5. How to Mend Broken China: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Mend Broken China: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Mend Broken China: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Attach the first detached piece to the base carefully by hand.
    • Adjust as needed.
    • Don't worry about excess epoxy at this point. It will be removed after setting.
  6. How to Mend Broken China: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Mend Broken China: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Apply epoxy on the next detached piece and the already mended piece
    • Use a tweezer to attach smaller fragments.
  7. How to Mend Broken China: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Mend Broken China: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Attach the piece to the china.
    • Adjust as needed
    • Repeat the process of applying epoxy and attaching the chips until all broken pieces are successfully in place.
  8. How to Mend Broken China: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place mended china in a container of stabilizing sand or gravel.
    • This step is performed to put the right gravitational weight on the attachments so the pieces don't become unaligned during the setting of the epoxy.
    • Leave to set for at least 1 hour.
  9. How to Mend Broken China: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Mend Broken China: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Shave off as much excess epoxy as possible using the razor.
    • Exhibit caution when using the razors; they are very sharp!
  10. How to Mend Broken China: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Mend Broken China: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use coarse sandpaper to further reduce the excess epoxy.
  11. How to Mend Broken China: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use fine sandpaper to smooth out remaining inconsistencies.
  12. How to Mend Broken China: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Mend Broken China: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Darker cracks form where the clear epoxy functions as filler, but the cup will work perfectly fine! Add colored pigment to the epoxy for a more subtle repair.
    Will I be able to drink/eat from chino repaired with epoxy? Is it washable? Paintable? Microwaveable?
    Cressy Cook - crwdns2934203:0crwdne2934203:0
Mikkeline Thomsen
crwdns2935283:004/28/17crwdne2935283:0
141 crwdns2915208:0crwdne2915208:0
UC Davis, Team S1-G4, Coad Spring 2017 crwdns2935289:0UC Davis, Team S1-G4, Coad Spring 2017crwdne2935289:0
UCD-COAD-S17S1G4
Will this method work on ceramic?
Terry - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 25
crwdns2936753:030crwdne2936753:0 142
crwdns2942667:0crwdne2942667:0 22,226
