If your Xbox can't power on, or your disc drive is cluttered/clogged, you may still need a way to eject the discs without disassembling the disc drive. This simple and easy guide will help you.
This guide should also work on the Xbox One S and Xbox One X. Visuals and placement may vary, but the end result will stay the same.
Find a thin pin or unfolded paperclip
Insert the makeshift device into a small hole below the sync button. Push it as far as it'll go and your discs should pop out.
This should work anytime you ever need it.
