This fix can be done without a sewing machine and instead be hand-sewn, however a sewing machine is recommended. The estimated time for this project is half an hour to 45 minutes. Allow extra time for seam ripping.
Start by carefully ripping the seam of the pants with a seam ripper. Make sure not to leave holes in the fabric or it will show in the finished product.
Next, iron the crease left previously by the seam.
Try on the pants. Have a partner pin the pants to the desired length.
If you do not have someone to help, measure the inseam of the pants and pin to the desired length.
Measure the width of the pant leg, double that measurement, and add 1.5 inches for seam allowance. Cut the bias tape to match this width.
Sew the bottom of the pant to the edge of the bias tape.
Fold the bias tape underneath (about 3/4" -1") and iron flat. Make sure that the bias tape is not visible. Pin the two layers together.
Repeat steps 1-7 for the other pant leg and iron flat.
