This guide shows how to increase the hard drive size of the 2013-2017 MacBook Air 13" (A1466), by adding an M2 SSD.
You'll need:
- NVME M.2 SSD - I used samsung 970 EVO Plus 250 GB NVME M.2
- Sintech Adapter kit e.g. https://mackabler.dk/ngff-m2-pcie-ssd-ko...
- Alternatively you may use OWC SSD, which does not require adapter - see https://www.owcdigital.com/products/aura....
- However OWC ssds are slower than the newest Samsung SSDs.
- Recovery USB disk with OSX - ref https://support.apple.com/en-in/HT201372 I used Catalina.
Boot in recovery mode (power + alt) to start from recovery disk.
Then format the new SSD in Disk Utility (erase + first aid).
Shutdown down mac, remove back plate, disconnect battery.
Then install new SSD in M2 enclosure and swap it with old SSD.
Mount external USB disk from (2).
Finally, restore time machine backup from (2) to new SSD.
