How to Grease the Barreto Trencher E718MTH4S 2016
  1. How to Grease the Barreto Trencher E718MTH4S 2016, Engage the hub lock pins: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Grease the Barreto Trencher E718MTH4S 2016, Engage the hub lock pins: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Grease the Barreto Trencher E718MTH4S 2016, Engage the hub lock pins: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Make sure that both ignition switches are turned to the off position. There is one on the engine and one on the control panel.
    • Pull the ring near one of the wheel hubs straight out, away from the wheel.
    • Rotate it so that the small roll pin lines up with its slot.
    • Release the ring so that the lock pin slides into the wheel. You may need to rotate the wheels a little before the lock pin fully engages.
    • With the pin engaged, it should be very hard to turn the wheels.
    • Repeat this step so that the lock pins on both wheels are engaged.
  2. How to Grease the Barreto Trencher E718MTH4S 2016, Connect the grease gun: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Grease the Barreto Trencher E718MTH4S 2016, Connect the grease gun: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Clean any dirt or debris off of the Zerk fitting before applying grease.
    • Slide the grease gun nozzle straight onto the Zerk fitting on the left side of the chain roller assembly.
    • Push the nozzle until you feel the nozzle snap into place on the fitting.
    • Depending on how big your grease gun nozzle is, the nut around the fitting might stop the nozzle from fully snapping into place. In this case, hold the nozzle in place while you use the grease gun.
  3. How to Grease the Barreto Trencher E718MTH4S 2016, Grease the chain roller assembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Grease the Barreto Trencher E718MTH4S 2016, Grease the chain roller assembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the nozzle securely attached to the Zerk fitting, pump the grease gun to grease the assembly.
    • Continue pumping until you start to see excess grease come out of the Zerk fitting.
    • Remove the nozzle and wipe away any excess grease.
  4. How to Grease the Barreto Trencher E718MTH4S 2016, Grease the axle: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Grease the Barreto Trencher E718MTH4S 2016, Grease the axle: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Grease the Barreto Trencher E718MTH4S 2016, Grease the axle: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Clean any dirt or debris off of the two Zerk fittings on either end of the axle.
    • Attach the grease gun to one of the axle Zerk fittings and repeat steps two and three to grease the axle.
    • Repeat with the Zerk fitting on the other end of the axle.
  5. How to Grease the Barreto Trencher E718MTH4S 2016, Grease the spindle: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Grease the Barreto Trencher E718MTH4S 2016, Grease the spindle: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Clean any dirt or debris off the Zerk fitting on the spindle.
    • Attach the grease gun to the Zerk fitting on the spindle and repeat steps two and three to grease the spindle.
Adam O'Camb
crwdns2935283:004/11/15crwdne2935283:0
214,541 crwdns2915208:0crwdne2915208:0
crwdns2935297:0416crwdne2935297:0
crwdns2942667:0crwdne2942667:0 1,229
