How to Fix the Worx Pegasus Workbench lower tray
  1. How to Fix the Worx Pegasus Workbench lower tray, Re-assemble per factory: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix the Worx Pegasus Workbench lower tray, Re-assemble per factory: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If yours became detached, make sure you begin by manually re-assembling the tray as it came from factory.
  2. How to Fix the Worx Pegasus Workbench lower tray, Drill through the hinge: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix the Worx Pegasus Workbench lower tray, Drill through the hinge: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Drill a small hole, the smallest possible but large enough to allow a zip tie to go through. I used a 1.5mm drill bit.
  3. How to Fix the Worx Pegasus Workbench lower tray, Route a Zip Tie: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix the Worx Pegasus Workbench lower tray, Route a Zip Tie: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Route a Zip Tie through the hole you just drilled and around the hinge barrel.
    • Cut the excess with scissors or wire cutters.
    • Do this procedure at least on two hinges: the leftmost and rightmost. For best results, address all six hinges.
  4. How to Fix the Worx Pegasus Workbench lower tray, Enjoy your reliable workbench: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If done correctly, the tray is not going to fail again.
    • This fix also adds a little bit more strength to the lower tray.
    • Enjoy!
RodCastler
crwdns2935283:010/29/22crwdne2935283:0
403 crwdns2915208:0crwdne2915208:0
Nice job. Only critique is a better or close up of where you drill the holes for the zip ties. Hard to see from your pics. I figured it out and added all 6 to my hinges as that tray falls off non-stop. Thanks! I also added 4 other zip ties to the 4 small exterior holes on the outside of the tray that lock the perimeter attachment hinges into place as well.
Ray Wright - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 590
