If your Sorrento Grey Reclining Loveseat (model 59928-028-1X) has a seat that is not secured properly, use this guide to replace the seat’s sliding mechanism to resolve the issue of the failing seat.
The sliding mechanism holds the seat in place, so that it can move when a person reclines or rock the seat. A faulty sliding mechanism will cause the seat to slip and malfunctioning will occur.
Before using this guide, inspect the loveseat for any loose components where the seat and its base connects. Typically, the sliding mechanism from the seat should be fixed to the wood of the seat. Be sure the seat base is properly secured and no components have become unattached.
Step 1 and Step 9 requires that the loveseat be turned over. If you do not feel comfortable with this step, then seek help before beginning.
Before beginning, make sure to unplug the power chord coming from the loveseat and store it in its storage unit. Locate the storage unit on back side of loveseat after unzipping the zipper.
Turn the Sorrento Grey Loveseat over.
Remove the snap cover that is covering the back to show the seat's sliding mechanism.
Pull off the seat connected to its base by pulling the clamps on both sides outward and the seat towards your body.
Align the hole of the sliding mechanism to hole on the wood of the seat.
Insert a screw into the hole and secure a bolt on the end.
Use a drill and vice grips to secure the bolt on the screw.
Attach the seat back onto the loveseat.
Use force to lock the seat into place.
Cover the sliding mechanisms with the snap cover.
Guide and place the loveseat back into upright position.
