How to Fix an Unwinding Tape Measure
  1. How to Fix an Unwinding Tape Measure, How to Fix an Unwinding Tape Measure: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grab your broken tape measure and inspect so that it doesn't retract.
    • Make sure it is not locked.
  2. How to Fix an Unwinding Tape Measure: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix an Unwinding Tape Measure: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 3mm Phillips #1 screws on the case around the clip.
    • Remove the 3mm Phillips #1 screw from the center of the clip.
  3. How to Fix an Unwinding Tape Measure: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix an Unwinding Tape Measure: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix an Unwinding Tape Measure: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Separate the two halves of the case by pulling them apart.
  4. How to Fix an Unwinding Tape Measure: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix an Unwinding Tape Measure: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Begin unwinding your tape measure until you get to the end of the tape.
    • Remember to be careful when retracting so that the spring doesn't come out or you hurt someone when the whole tape is out.
  5. How to Fix an Unwinding Tape Measure: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix an Unwinding Tape Measure: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • When the whole tape is out, slowly begin rolling it back in.
    • Roll it back in keeping your thumb firmly pressed on the wheel so that it goes back in smoothly and won't come out.
    • Once you start reaching the end, keep the tape straight with your thumb so that it retracts with no inconveniences.
  6. How to Fix an Unwinding Tape Measure: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix an Unwinding Tape Measure: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once you have rolled the tape in again, place the top back on making sure the tape doesn't come out or roll out by itself.
    • Remember to keep your thumb on the wheel as you put on the top so that it doesn't come out and hurt anyone!
  7. How to Fix an Unwinding Tape Measure: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Begin placing the screws back in to their respective places and screwing them back in tightly.
    • Do this as you apply pressure on the top so that no parts come out.
  8. How to Fix an Unwinding Tape Measure: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once your screws are back on, check your tape measure to see if it works properly or not.
    • If it isn't working the way you wanted to, repeat steps 2-7.
    This tells you how to take it apart. It does not tell you how to repair it, or how to PRETENSION the SPRING prior to final assembly!!!
    Chuck - crwdns2934203:0crwdne2934203:0
Lorena Sanabria
crwdns2935283:001/28/20crwdne2935283:0
319 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S11-G2, Salas Spring 2020 crwdns2935289:0Embry-Riddle Aeronautical University, Team S11-G2, Salas Spring 2020crwdne2935289:0
ERAU-SALAS-S20S11G2
Wat te doen als de veer van het oprolmechanisme los is gekomen?
Adri - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 44
crwdns2936753:07crwdne2936753:0 358
crwdns2936753:030crwdne2936753:0 1,635
crwdns2942667:0crwdne2942667:0 58,785
