How to Fix an Umbrella Rivet
  1. How to Fix an Umbrella Rivet, How to Fix an Umbrella Rivet: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the umbrella into its proper position.
  2. How to Fix an Umbrella Rivet: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Identify the broken stretcher that needs to be repaired.
  3. How to Fix an Umbrella Rivet: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Close the umbrella halfway to release the tension in the stretchers.
    • This makes it easier to line up the holes in the next step.
  4. How to Fix an Umbrella Rivet: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take the two pieces of the broken stretcher and line up the rivet holes.
  5. How to Fix an Umbrella Rivet: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pass the 6" piece of wire through the rivet holes.
  6. How to Fix an Umbrella Rivet: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wrap the wire around the stretcher and thread it through the holes again.
    • Repeat until there is no more room to pass the wire through.
    • May need to use the pliers to get a better grip on the wire so it can be pulled tight.
  7. How to Fix an Umbrella Rivet: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Tie two half-hitch knots with the wire.
    • If you do not know how to tie a half-hitch knot, follow the link provided at the beginning of the guide.
  8. How to Fix an Umbrella Rivet: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the scissors to trim the two ends of the wire to about half an inch in length.
  9. How to Fix an Umbrella Rivet: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the pliers, twist the ends of the wire together.
  10. How to Fix an Umbrella Rivet: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Tuck the wires down and clamp with the pliers so the ends are not poking out.
Alexandra Hamelin
crwdns2935283:006/08/16crwdne2935283:0
297 crwdns2915208:0crwdne2915208:0
Texas Tech, Team 3-8, Rauch SU 2016 crwdns2935289:0Texas Tech, Team 3-8, Rauch SU 2016crwdne2935289:0
TTU-RAUCH-SU16S3G8
crwdns2947412:07crwdne2947412:0
This is not called an ‘umbrella rivet replacement’.
SouthPark - crwdns2934203:0crwdne2934203:0
I fixed my umbrella! Thank you. Umbrella is very old though, will see how much more time I can buy with this fix :)
Lou - crwdns2934203:0crwdne2934203:0
The fix lasted about a month and a half and then the copper wire broke. I am trying the same technique but this time with a metal paper clip that I had. The paper clip is made of metal that's thicker than the copper wire. I only threaded it through one time and then twisted the ends. One paper clip was enough to fix 2 rivets (both the original one and a new one is now broken as well). I will try to report back if these also break.
6 months later and paperclip fix is still holding!
Lou -
Thanks! A paperclip worked!
Mayra L. -
crwdns2936751:024crwdne2936751:0 21
crwdns2936753:07crwdne2936753:0 107
crwdns2936753:030crwdne2936753:0 473
crwdns2942667:0crwdne2942667:0 30,191
