How to Fix an Overextending Holga 120N Camera Shutter
  1. How to Fix an Overextending Holga 120N Camera Shutter, How to Fix an Overextending Holga 120N Camera Shutter: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix an Overextending Holga 120N Camera Shutter, How to Fix an Overextending Holga 120N Camera Shutter: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the two metal lanyard locks up and off the camera.
    • Pop the back of the camera off.
  2. How to Fix an Overextending Holga 120N Camera Shutter: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix an Overextending Holga 120N Camera Shutter: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screw above the opening to the shutter piece using a Phillips #00 screwdriver.
    • Remove the screw below the opening to the shutter piece using a Phillips #00 screwdriver.
  3. How to Fix an Overextending Holga 120N Camera Shutter: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the shutter piece out and away from the camera.
    • Pull the shutter piece away carefully to avoid snapping the wire.
  4. How to Fix an Overextending Holga 120N Camera Shutter: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix an Overextending Holga 120N Camera Shutter: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix an Overextending Holga 120N Camera Shutter: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Cut off the spade terminal's right prong with scissors.
  5. How to Fix an Overextending Holga 120N Camera Shutter: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Bend the spade terminal forward at a 90-degree angle.
  6. How to Fix an Overextending Holga 120N Camera Shutter: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix an Overextending Holga 120N Camera Shutter: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slice the blue plastic off of the spade terminal with the boxcutter/Exacto-knife.
    • The plastic bottom is sealed on very tightly. Use caution when cutting it away!
    • Remove the plastic from the spade terminal.
  7. How to Fix an Overextending Holga 120N Camera Shutter: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix an Overextending Holga 120N Camera Shutter: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix an Overextending Holga 120N Camera Shutter: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place hot glue at the bottom of the spade terminal.
    • Place the spade terminal in the small hole underneath the shutter.
    • Point the spade terminal horizontally, facing the wire that leads back to the camera.
  8. How to Fix an Overextending Holga 120N Camera Shutter: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Screw the shutter piece back into place using a Phillips #00 screwdriver.
  9. How to Fix an Overextending Holga 120N Camera Shutter: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix an Overextending Holga 120N Camera Shutter: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Return the back of the camera into place.
You’ve now learned the following:
  • How to disassemble and reassemble a Holga 120N camera
  • How to add a spade terminal as a blocker
The spade terminal will stop the overextended shutter. Enjoy taking pictures!
Jacob DeLany
crwdns2935283:009/28/21crwdne2935283:0
196 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 2-14, Raign Fall 2021 crwdns2935289:0University of North Texas, Team 2-14, Raign Fall 2021crwdne2935289:0
UNT-RAIGN-F21S2G14
That's a PZ1 bit which gets the screws out easily. If you got the screws out with a PH00 bit, either they changed the way the camera is made before mine was made or you are quite tenacious in your screwdriving.
s l - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 75
crwdns2942667:0crwdne2942667:0 2,128
