How to Fix an OXO Container's Jammed Button
Allen Wong
crwdns2944107:0crwdnd2944107:0Allen Wongcrwdnd2944107:0crwdnd2944107:0crwdnd2944107:04crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Nhl 18, 2023crwdne2944111:0
10 - 15 crwdns2931279:0crwdne2931279:0
crwdns2937799:0crwdne2937799:0
crwdns2942287:0crwdne2942287:0
Follow this guide to fix a jammed OXO POP container's button. (Skip to step 4 if the button is not jammed and stays protruded.) The OXO POP container is a one-handed airtight storage most commonly used in the kitchen for storing foods. Additionally, it is handy for tidying up and organizing outside the kitchen. This specific container we worked on was bought from Costco, though it can also be found at most department stores or home improvement retailers, such as Target and Home Depot.
There are little metal prongs attached underneath the button that catch onto a mechanism in the lid. Sometimes, the prongs will bend after constant usage, causing the button to become stuck. Fear not! This can be easily fixed by taking the lid apart and bending the prongs back into the right shape. (Refer to steps 3 and 5 to see how the tools were used.)
crwdns2944105:0crwdne2944105:0
  1. How to Fix an OXO Container's Jammed Button, How to Fix an OXO Container's Jammed Button: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix an OXO Container's Jammed Button, How to Fix an OXO Container's Jammed Button: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix an OXO Container's Jammed Button, How to Fix an OXO Container's Jammed Button: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Hold the lid with the button facing down.
    • Twist the flat part in the direction of the arrows or counter clockwise.
  2. How to Fix an OXO Container's Jammed Button: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix an OXO Container's Jammed Button: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix an OXO Container's Jammed Button: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Firmly pinch both the half-moon shaped openings.
    • Pull up the removed outer piece and set it aside.
  3. How to Fix an OXO Container's Jammed Button: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the lid perpendicular and onto the top of the container's opening.
    • The button should pop out. Placing the lid on a flat surface will prevent them from coming out.
    • Locate the two holes.
  4. How to Fix an OXO Container's Jammed Button: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix an OXO Container's Jammed Button: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With a tool in each hand, insert them into the openings of the buttons.
    • Make sure the two tools are centered on the plastic in the openings.
    • Tools must be small enough to fit inside the openings - alternatives to spudgers work.
    • Firmly press downwards until the button pops out.
    • Applying a lot of pressure is necessary, but also may damage the plastic of the lid.
  5. How to Fix an OXO Container's Jammed Button: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix an OXO Container's Jammed Button: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the lid so the button faces up.
    • It should be easy to pinch the sides of the button so that it pops up.
    • Pinch the two sides and gently pull up.
    • Remove the button.
  6. How to Fix an OXO Container's Jammed Button: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix an OXO Container's Jammed Button: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix an OXO Container's Jammed Button: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the button so the inside wire faces upwards.
    • Use pliers to bend the wire similar to its original shape.
    • Use the unbent wire as a reference to reshape the bent wire.
To reassemble your device, squeeze the button back onto the lid and follow these instructions in reverse order.
Allen Wong
crwdns2935283:002/03/23crwdne2935283:0
133 crwdns2915208:0crwdne2915208:0
UC Davis, Team 2-5, Andersen Winter 2023 crwdns2935289:0UC Davis, Team 2-5, Andersen Winter 2023crwdne2935289:0
UCD-ANDERSEN-W23S2G5
crwdns2936753:07crwdne2936753:0 31
crwdns2936753:030crwdne2936753:0 175
crwdns2942667:0crwdne2942667:0 5,242
