How to Fix an Air Tech 2K0 Aquarium Pump
  1. How to Fix an Air Tech 2K0 Aquarium Pump, How to Fix an Air Tech 2K0 Aquarium Pump: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix an Air Tech 2K0 Aquarium Pump, How to Fix an Air Tech 2K0 Aquarium Pump: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Begin disassembling the air pump by removing the screws (2.9mm x 13mm) with the small Philips screwdriver.
  2. How to Fix an Air Tech 2K0 Aquarium Pump: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix an Air Tech 2K0 Aquarium Pump: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the cover of the air pump to expose the inside of it.
    • Set aside the three screws (2.9mm x 13mm) and cover to save for reassembly at the end of the guide.
  3. How to Fix an Air Tech 2K0 Aquarium Pump: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix an Air Tech 2K0 Aquarium Pump: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix an Air Tech 2K0 Aquarium Pump: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the round, rubber cover called the diaphragm.
  4. How to Fix an Air Tech 2K0 Aquarium Pump: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix an Air Tech 2K0 Aquarium Pump: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix an Air Tech 2K0 Aquarium Pump: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the entire piece is removed, unscrew the the rubber diaphragm from the metal part.
    • Begin by twisting off the washer.
    • From here, remove the metal piece and the screw (1.25mm x 8mm) from the center of the diaphragm.
  5. How to Fix an Air Tech 2K0 Aquarium Pump: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix an Air Tech 2K0 Aquarium Pump: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix an Air Tech 2K0 Aquarium Pump: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the diaphragm has been separated, set aside the metal piece, the screw (1.25mm x 8mm), and the washer.
    • Examine the diaphragm for damage.
    • Here, you can see a hole in the diaphragm that needs to be repaired.
  6. How to Fix an Air Tech 2K0 Aquarium Pump: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix an Air Tech 2K0 Aquarium Pump: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix an Air Tech 2K0 Aquarium Pump: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the Gorilla Glue, coat the diaphragm on both the inside and outside of the damaged area to ensure adhesion.
    • Make sure the entire area is covered as pictured - it's okay if it looks messy.
  7. How to Fix an Air Tech 2K0 Aquarium Pump: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Allow the glue to dry thoroughly before reassembling the air pump.
  8. How to Fix an Air Tech 2K0 Aquarium Pump: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix an Air Tech 2K0 Aquarium Pump: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix an Air Tech 2K0 Aquarium Pump: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • From here, follow Step 4 in reverse to reassemble the diaphragm and its attached metal piece:
    • Insert the screw (1.25mm x 8mm) through the hole of the diaphragm.
    • Place the metal piece flush against the back of the diaphragm, making sure to line up the screw with the hole.
    • Finally, screw the washer back on to ensure a secure fit between all the pieces.
  9. How to Fix an Air Tech 2K0 Aquarium Pump: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix an Air Tech 2K0 Aquarium Pump: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the reassembled diaphragm back into the slot you initially removed it from.
  10. How to Fix an Air Tech 2K0 Aquarium Pump: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the cover back on the air pump, lining up the holes for the three screws (13mm x 2.9mm).
  11. How to Fix an Air Tech 2K0 Aquarium Pump: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix an Air Tech 2K0 Aquarium Pump: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix an Air Tech 2K0 Aquarium Pump: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the three screws (2.9mm x 13mm) and use the Philips screwdriver to secure them in place.
    • Once the cover is on securely, you will be able to reconnect the tubing, and you should have bubbles!
Madeline Kovach
crwdns2935283:003/22/21crwdne2935283:0
247 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S3-G9, Saloman Spring 2021 crwdns2935289:0UMass Dartmouth, Team S3-G9, Saloman Spring 2021crwdne2935289:0
UMASSD-SALOMAN-S21S3G9
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 1,543
