Many people can find it difficult to fix a broken bed fan even though, most of the time, it's quite easy. No particular skills are required, many of the processes are simple, and you only need to know how to use a screwdriver. There is a minimal risk; it is advised to unplug the fan from any outlet because that is the only possible danger.
This manual is crucial since it deconstructs and makes repair of any damaged fan simple. The main goal of this article is to make it clearer how to fix a broken bed fan.
Take out the front metal grill.
By the side of the cover, there's a metal piece you have to flick open to get the front and back unlocked from each other.
Turn the knob to take out the blade cap.
Spin the knob counterclockwise. This way, you are loosening the knob.
Loosen the plastic nut on the rear grille in order to take the rear grille out.
Unscrew the plastic on the fan motor, and gently pull the slide open: There are four screws, proceed to taking off the plastic plates.
Apply machine oil onto the rusted parts.
Take the machine oil and make sure you apply the oil to the around fan rotor
Carefully place the plastic plate properly on the surface of the fan rotor.
Make sure the screws align with the holes on the fan motor, then proceed to screw.
Place back the fan rear grill, pick up the plastic grill nut.
fit in the hole and screw down the fan rear grill upon the fan motor.
Place the blade right back into the motor pin.
Take the blade, make sure the blade sit on the fan edges.
Take the circlip, spin the circlip right on the blade, ensure it is tight.
Pick up the front grille, ensure the grille aligns with the metal piece around the fan.
Then lock the metal piece, this way the front and the rear grilles are locked.
