How to Fix a Wobbly Leg on a Solid Wood Chair
  1. How to Fix a Wobbly Leg on a Solid Wood Chair, How to Fix a Wobbly Leg on a Solid Wood Chair: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • First, thoroughly assess your chair for loose elements.
    • Sit and jiggle them to test and note exactly what moves.
  2. How to Fix a Wobbly Leg on a Solid Wood Chair: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix a Wobbly Leg on a Solid Wood Chair: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix a Wobbly Leg on a Solid Wood Chair: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Position an L-bracket as if it will brace the leg to the frame of the chair.
    • Mark the exact outline of the bracket, taking extra care when marking the center hole where your screws will hold the brace in place.
    • It might be beneficial to "x" the through the marked circles to approximate the exact center for the screw to enter.
  3. How to Fix a Wobbly Leg on a Solid Wood Chair: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix a Wobbly Leg on a Solid Wood Chair: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If possible, detach your chair legs.
    • In the case you cannot detach your chair legs, consider buying longer L-brackets so you still have enough room to hold your drill parallel to the chair surfaces.
  4. How to Fix a Wobbly Leg on a Solid Wood Chair: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Check if the drill bit is longer than the width of the chair leg.
    • If so, consider marking the drill bit to your desired depth.
  5. How to Fix a Wobbly Leg on a Solid Wood Chair: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix a Wobbly Leg on a Solid Wood Chair: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix a Wobbly Leg on a Solid Wood Chair: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before drilling any holes, ensure that your drill bit is slightly smaller than the width of your screw. This will result in a more secure hold.
    • Pre-drill holes through the center of your marked circles on both your chair legs and chair frame.
  6. How to Fix a Wobbly Leg on a Solid Wood Chair: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix a Wobbly Leg on a Solid Wood Chair: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the drill, secure your L-brackets to the chair legs first.
    • Be sure to hold the drill and screw parallel to the drilling surface.
  7. How to Fix a Wobbly Leg on a Solid Wood Chair: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • For extra hold and durability, use a small amount of wood glue at the chair legs joints.
    • Be sure to wipe away any excess wood glue.
  8. How to Fix a Wobbly Leg on a Solid Wood Chair: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix a Wobbly Leg on a Solid Wood Chair: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Tighten any preexisting hardware holding the legs to the chair base before fixing the L-bracket to the chair.
  9. How to Fix a Wobbly Leg on a Solid Wood Chair: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix a Wobbly Leg on a Solid Wood Chair: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Finally, screw the second side of the L-bracket to the base of the chair.
Reassemble any remaining loose pieces as they were disassembled unless otherwise noted.
Dhvani Thakkar
crwdns2935283:004/28/17crwdne2935283:0
178 crwdns2915208:0crwdne2915208:0
UC Davis, Team S2-G6, Cole Spring 2017 crwdns2935289:0UC Davis, Team S2-G6, Cole Spring 2017crwdne2935289:0
UCD-COLE-S17S2G6
My entire corner wood pieces are broken and not fixable and the screen (bolt and nut) is bended also. I would like to purchase those small wood pieces, I am not a saavy. Need some help to find the pieces. you can mail me @ radhu_murali@hotmail.com.
Radhika Murali - crwdns2934203:0crwdne2934203:0
My neighbor called and said she had a table. She brought it outside but before I could make it across the street someone took the legs. Miraculously I found legs from another table the next day. Unfortunately the screw hole didn’t match. The table was wobbly. This is the almost perfect fix.
WillowBees Naturally - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 12
crwdns2936753:07crwdne2936753:0 79
crwdns2936753:030crwdne2936753:0 278
crwdns2942667:0crwdne2942667:0 34,971
