Owning a small living room table that wobbles effortlessly can lead to issues that can happen very often. Issues such as small flat-faced portraits, disorganized shelfed items, and lots of falling valuable item that gets put that get destroyed. To solve this issue, I would like to demonstrate to you the steps on how to repair a small living room table to its regular state.
The steps and tools used for this guide is pointed to be used on tables such as this model in the guide.
Before starting, make sure to check all four legs of the table so you could know which one required to be repaired. You might even have to repeat this method more than once for each leg if possible.
Have the table flipped over on the top of its shelf.
Use your Philip 6 screwdriver to twist the screws off the leg of the table.
Take the top off the wood glue.
Use your scissors to cut open the top in order for the substance to be squeezed out.
Squeeze the wood glue gently into the screw holes.
Take the leg and place it gently back to its former position.
Take all the screws and put them back to their original holes. Then use the Phillip 6 screwdriver to twist screw back into the hole.
Have the table placed into a safe location and let its it for at least half an hour or 30 minutes.
Once the minutes have passed, have the table flipped over on 4 of its legs and give it a little shake to make sure that the glue took its effect.
Once have finished this guide, your stand will be free from slanting in no time.
