You know the story, you go to a thrift store hoping today’s the day to find the perfect vintage rock T-shirt hidden in a pile. You finally find it, but then you realize it’s a size XXXL and it doesn’t fit you. Follow this guide to make that too-large-tee fit just right.
Restructuring your T-shirt is a relatively easy process for people who have basic sewing knowledge and experience using a sewing machine.
Lay the larger T-shirt on a flat surface.
Take another T-shirt that fits you perfectly and lay it on top of the larger T-shirt.
Double-check that the neckline is straight and the graphic on the larger T-shirt has plenty of room on either side.
Use a water-soluble fabric marker to trace the small T-shirt out on the larger one.
Use scissors to cut off the excess material.
Using pins, put the sleeves together in order to give a crease.
Pin the rest of the unsewn edges to get a rough idea of whether it is the correct size.
Use your sewing machine to sew the parts of the shirt together.
Go back over with a smaller stitch to secure the parts of the shirt.
Use scissors to cut any extra threads left over from the project.
