How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine
crwdns2869540:0crwdne2869540:0: 1.4K
3
27
167
1,447
crwdns2959984:0crwdne2959984:0: 2
crwdns2959974:02crwdne2959974:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:040crwdne2931287:0
crwdns2955970:0crwdne2955970:0: crwdns2937799:0crwdne2937799:0
crwdns2862591:0crwdne2862591:0
crwdns2862592:0crwdne2862592:0
Over time, the Brother SC 9500 computerized sewing machine begins to make a high-pitched metallic squeak when the needle rises and falls. The sound is usually the combination of two issues: 1) dust build up in the feed dogs and bobbin well; and 2) a dry joint in the needle arm mechanism that requires oiling. Addressing these two problems stops the squeaking. Let's begin!
    1. How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine, How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Flip the power switch on the back end of the sewing machine to "off."
      • For extra security, also unplug the power cord entirely.
    2. How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove any thread spools from the machine and set aside.
      • You don't want any thread in the machine while cleaning it.
    3. How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Slide the bobbin plate lock switch to the right.
      • The plate cover will pop open.
      • Remove the plate cover.
      • Remove the bobbin (if you have one loaded).
    4. How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Locate the presser foot release switch on the back of the presser foot.
      • Squeeze the release switch gently.
      • The pressure foot will drop away. Set it aside for later.
    5. How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a coin to twist the needle securing screw towards yourself (counterclockwise).
      • The needle will drop down when it's loose enough. Carefully set the needle aside.
    6. How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a coin to unscrew the two screws holding the bobbin well cover plate in place.
      • The first screw is located in the middle of the grid lines on the metal plate. The second screw is located in the top right corner of the metal plate.
      • Lift the well cover plate from the left edge first to remove it.
    7. How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Pinch the black bobbin well and lift it up and away from the bobbin well tray to remove it.
      • Do not rotate the bobbin well when you remove it (maintain the same orientation). This makes it easier to replace the well at the end.
    8. How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a straw cleaner to remove dust and lint from the bobbin well tray.
      • You should also use the straw cleaner to clean between the metal teeth on the feed dogs.
    9. How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Replace the bobbin well once all the dust is gone.
      • Make sure the black tab on the black bobbin well is placed right up against the metal spring in the bobbin well tray.
      • If it's not aligned properly, your machine will not work. When you twist the black bobbin well counterclockwise, the plastic tab should depress the metal spring.
    10. How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Replace the bobbin well plate cover and the two screws.
    11. How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Turn the machine around to the back and unscrew the single screw on the far right edge.
      • The faceplate screw is set about an inch into the plastic body of the machine.
      • Pinch the bottom edge of the faceplate and pull up to detach.
    12. How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use the straw cleaner to dust the top, bottom left, and inner right sides of the internal needle arm mechanism.
    13. How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Locate the inner joint. It looks like a large round disk in the right side of the needle arm mechanism.
      • A flashlight is helpful to locate the joint.
      • Apply two drops of sewing machine oil to this joint.
    14. How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn the hand wheel on the end of your machine two full times clockwise to spread the oil around the joint.
    15. How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Replace the faceplate.
      • Slot the top edge over the exposed inner mechanism first.
      • Lower the faceplate cover until it snaps into place at the bottom.
      • Replace the screw of the back of the machine until it is hand-tight.
    16. How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Align the presser foot bar with the presser foot clip.
      • Pull down on the presser foot lever to push the clip into the bar. It will audibly snap into place.
      • Push the presser foot lever up to check that the presser foot is secure.
    17. How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix a Squeaky Brother SC 9500 Computerized Sewing Machine: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lastly, carefully replace the needle.
      • Sewing machine needles have a round front and a flat back. Insert the needle with the flat back facing away from you.
      • Use a coin to tighten the needle screw clockwise until it is hand-tight.
Congratulations! Your sewing machine is ready to be re-threaded and used. Enjoy sewing squeak-free.
crwdns2935291:0crwdne2935291:0
Daelyn Bentley-Gottel
crwdns2935283:001/16/24crwdne2935283:0
319 crwdns2915208:0crwdne2915208:0
Northern Arizona University, Team 1-1, Konrad Spring 2024 crwdns2935289:0Northern Arizona University, Team 1-1, Konrad Spring 2024crwdne2935289:0
NAU-KONRAD-S24S1G1
crwdns2936753:030crwdne2936753:0 167
crwdns2959996:0crwdne2959996:0 1,447
