How to Fix a Screw-less Jammed Flexi Retractable Dog Leash
  1. How to Fix a Screw-less Jammed Flexi Retractable Dog Leash, How to Fix a Screw-less Jammed Flexi Retractable Dog Leash: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix a Screw-less Jammed Flexi Retractable Dog Leash, How to Fix a Screw-less Jammed Flexi Retractable Dog Leash: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the detachable T-shaped opening at the bottom of the dog leash.
    • Insert a pry tool into the bottom of the "T".
  2. How to Fix a Screw-less Jammed Flexi Retractable Dog Leash: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix a Screw-less Jammed Flexi Retractable Dog Leash: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix a Screw-less Jammed Flexi Retractable Dog Leash: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert fingers into the gap made by the screwdriver and pull apart.
    • The case may take some effort to pry apart.
    • Completely separate the two halves of the case.
    • The leash lock, rope, roll, and detachable hole that allows the roll out of the case are not attached to the case and may fall out upon opening the case.
  3. How to Fix a Screw-less Jammed Flexi Retractable Dog Leash: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix a Screw-less Jammed Flexi Retractable Dog Leash: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix a Screw-less Jammed Flexi Retractable Dog Leash: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Examine the exposed components.
    • Leash Roll
    • Leash Rope
    • Leash Lock
    • Detachable hole that allows the rope out of the case
  4. How to Fix a Screw-less Jammed Flexi Retractable Dog Leash: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix a Screw-less Jammed Flexi Retractable Dog Leash: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up the leash lock to remove it from the case and place it aside.
  5. How to Fix a Screw-less Jammed Flexi Retractable Dog Leash: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix a Screw-less Jammed Flexi Retractable Dog Leash: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up the detachable hole that allows the rope out of the case. Remove it from the case and place it aside.
  6. How to Fix a Screw-less Jammed Flexi Retractable Dog Leash: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix a Screw-less Jammed Flexi Retractable Dog Leash: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Examine the coil of the rope around the roll to spot any issues.
    • Issues may include tangles, twists, knots, or debris.
    • Unravel the rope from the roll in a counter-clockwise motion.
    • Remove any tangles, twists, knots, or debris interfering with the rope.
  7. How to Fix a Screw-less Jammed Flexi Retractable Dog Leash: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Let the rope wind back up, making sure to keep it aligned, straight, and flat against the roll.
  8. How to Fix a Screw-less Jammed Flexi Retractable Dog Leash: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix a Screw-less Jammed Flexi Retractable Dog Leash: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Replace the detachable hole that allows the rope out of the case into its slot at the top of one of the case halves.
    • Keep the case on a flat surface after reattachment to ensure the leash opening does not fall out while replacing other components.
  9. How to Fix a Screw-less Jammed Flexi Retractable Dog Leash: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix a Screw-less Jammed Flexi Retractable Dog Leash: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the leash lock back into its place behind the detachable hole that allows the rope out of the case, and on top of the spring.
  10. How to Fix a Screw-less Jammed Flexi Retractable Dog Leash: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix a Screw-less Jammed Flexi Retractable Dog Leash: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix a Screw-less Jammed Flexi Retractable Dog Leash: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Find the locking screws on both halves of the cases.
    • Align the locking screws with their corresponding holes.
    • Place the two case halves atop one another and clamp the two halves together.
  11. How to Fix a Screw-less Jammed Flexi Retractable Dog Leash: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix a Screw-less Jammed Flexi Retractable Dog Leash: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix a Screw-less Jammed Flexi Retractable Dog Leash: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press together very tightly to finish reassembly.
crwdns2935229:011crwdne2935229:0
[deleted]
crwdns2935283:002/20/20crwdne2935283:0
292 crwdns2915208:0crwdne2915208:0
crwdns2947412:07crwdne2947412:0
Non vedo l'apertura a forma di T al di sotto del guinzaglio, è un Flexi Standard 2, come faccio ?
Atlas _ - crwdns2934203:0crwdne2934203:0
There was a rubber o-ring that fell out of mine but I can't tell where it goes. Anyone know?
Digital Oxygen Photography - crwdns2934203:0crwdne2934203:0
I took mine apart and put it back together, but now the only thing is it doesn’t wind the string automatically. The string will unwind and lock just fine, but it no longer pulls it back in, so the leash is stuck long unless I pull the thing apart and wind it back up manually
Persten Halverson - crwdns2934203:0crwdne2934203:0
The casing's axle is split in the middle, you have to pop the spring coil ( inside the tumble ) back into that slit in order to have the winding/pull back working
TheAero -
crwdns2936751:024crwdne2936751:0 63
crwdns2936753:07crwdne2936753:0 380
crwdns2936753:030crwdne2936753:0 1,679
crwdns2942667:0crwdne2942667:0 66,282
