Use this guide to fix the wobbly and squeaky arm rests for your “ Living Polyurethane Split Leather” Office Chair (model 068-0935-6).
When you have an office chair for work purposes and it has been over a few years since you got that chair, your arm rest starts becoming wobbly and noisy. It is usually the loose screws and dust particles that make it wobbly and squeaky. Follow this guide to remove the arm rests, clean the screw holes, and reassemble your chair—you won’t have loose arm rests when you’re through!
Use a hex key to undo all of the M3 x 6 mm alloy steel hex bolts.
Turn the hex key in the counter-clockwise direction to unscrew the bolts.
After removing the arm rest, get a Q-tip and start cleaning the bolt holes.
Adjust the arm so that each hole is aligned with the hole where the bolt goes in as shown in the picture.
Reassemble the arm rest and place the the bolts back as they were.
To tighten the bolts, turn the hex key in a clockwise direction.
Tighten the bolts and check to see if they are tight enough.
Check the arm rests to see if they are stiff and not wobbly
Check each bolt and tighten till the arm rest isn't wobbly.
Repeat Steps 1-6 for the other arm rest.
Suppose that the bolt is not hex or phillips or star, but is completely smooth and the fabric is closed with stitching. After removing the caps that cover the holes in the arm there is just a completely smooth bolt or screw with no way to grip or turn it?????
This is the dumbest tutorial I've ever seen. So essentially u say just tighten the bolts. Lol. What a joke.
At the very least say to put a lot of cotton on the hole so it will tighten the hole up when u put the screw in. And or put a washer on each bolt. What a joke.
