How to Fix a Damaged VHS Tape
  1. How to Fix a Damaged VHS Tape, How to Fix a Damaged VHS Tape: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix a Damaged VHS Tape, How to Fix a Damaged VHS Tape: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix a Damaged VHS Tape, How to Fix a Damaged VHS Tape: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the screws at the bottom of the VHS case using a Phillips #0 screwdriver.
  2. How to Fix a Damaged VHS Tape: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix a Damaged VHS Tape: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift open the cover of the VHS.
  3. How to Fix a Damaged VHS Tape: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix a Damaged VHS Tape: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the top cover of the VHS case.
  4. How to Fix a Damaged VHS Tape: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix a Damaged VHS Tape: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix a Damaged VHS Tape: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Replace any rollers that accidently fall out of the VHS case.
  5. How to Fix a Damaged VHS Tape: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix a Damaged VHS Tape: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix a Damaged VHS Tape: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unroll the video tape from each side of the VHS, running it through the rollers the correct way. Do this until you reach the damaged parts of the tape.
  6. How to Fix a Damaged VHS Tape: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix a Damaged VHS Tape: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix a Damaged VHS Tape: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Cut out the wrinkled and damaged parts of the VHS tape using scissors.
  7. How to Fix a Damaged VHS Tape: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Hold the undamaged parts of the tape over each other as evenly as possible.
  8. How to Fix a Damaged VHS Tape: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix a Damaged VHS Tape: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Cut the overlapping portion of the tape at an angle.
  9. How to Fix a Damaged VHS Tape: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix a Damaged VHS Tape: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Apply scotch tape to the dull side of the two matching halves of the VHS tape.
    • Potential for device damage: Do not wrap the scotch tape around the other side of the VHS tape.
    moeten de tape-einden naadloos aansluiten of mag er een overlap zijn??
    Jan van Gorsel - crwdns2934203:0crwdne2934203:0
  10. How to Fix a Damaged VHS Tape: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix a Damaged VHS Tape: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix a Damaged VHS Tape: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Cut excess scotch tape to match the size of the VHS tape as precisely as possible.
    Please be mindful to cut some scissors of the damaging part of the VHS 📼 tape. Try to cut the wrinkling part of the tape so that way when you put inside the vcr it will eat the tape and it won't be able to play or rewind at all.
    Patrick Noonan - crwdns2934203:0crwdne2934203:0
  11. How to Fix a Damaged VHS Tape: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix a Damaged VHS Tape: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix a Damaged VHS Tape: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Wind the loose VHS tape back into the case.
  12. How to Fix a Damaged VHS Tape: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix a Damaged VHS Tape: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix a Damaged VHS Tape: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Replace the cover back on top of the VHS case.
  13. How to Fix a Damaged VHS Tape: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix a Damaged VHS Tape: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix a Damaged VHS Tape: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Reinsert the screws through the bottom of the VHS tape.
    Super omschrijving, ik heb dit wel eens zien gebeuren toen ik nog bij SONY werkte (1968-1972). Maar uitvoeren leek me een lastige, klus. Maar nu zal ik er aan moeten geloven. Een beetje late reactie, omdat ik pas recent met dit probleem in aanraking kwam. In een geleende recorder/speler zat nog een band die niet automatisch kon worden uitgegooid (eject). Behuizing van de recorder/speler open gemaakt en de vastgelopen/gescheurde tape losgemaakt. Ik ga een poging wagen om die tape eerst te repareren en te testen, en dan mijn tape af te spelen en hopelijk te converteren naar een bestand, en dan naar CD.
    Jan - crwdns2934203:0crwdne2934203:0
Nicholas Monroe
crwdns2935283:003/23/21crwdne2935283:0
265 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S1-G6, Gulbrandsen Spring 2021 crwdns2935289:0UMass Dartmouth, Team S1-G6, Gulbrandsen Spring 2021crwdne2935289:0
UMASSD-GULBRANDSEN-S21S1G6
Na het monteren van de tape, en voor het sluiten van de cassette hield ik nog een klein zwart onderdeeltje over en kan het niet meer herplaatsen, deel omdat de behuizing nagenoeg zwart is, en ook omdat ik niets wil forceren. Zou een tip om de plaats van dit onderdeel te vinden enorm op prijs stellen.
Inmiddels van iemand een VHS band geleend, opengemaakt en vastgesteld waar het blokje past, bij de afbeelding 4 en 5 is dat helaas slecht te zien, maar het blokje past in een kleine ruimte tussen de twee spoelen. Het zou mooi zijn, als je plaatjes kon toevoegen, maar goed probleem opgelost, en nu opnieuw met de videograbber aan de slag, wat leveren de Kabelshop en NEDIS een slecht service, door steeds verwijzen dat het aan de kabel ligt, de videospeler, of de aansluiting met de Windows PC, feitelijk stijllloos.
domz - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 51
crwdns2936753:030crwdne2936753:0 195
crwdns2942667:0crwdne2942667:0 10,560
