How to Fix a Broken Necklace Chain
crwdns2942287:0crwdne2942287:0Have a broken necklace still lying around because you can't bear to get rid of it? This simple guide to repairing the chain will make it wearable again in no time.
Use the needle nosed pliers to separate the closure of a link on one side of the break.
Hook the closed link opposite the break to the open link.
Using the needle nosed pliers, squeeze the ends of the open link together.
Using the needle nosed pliers, squeeze the closure so that the ends of the link are flush with one another.
Test the closure by gently pulling it from either side. If it comes apart repeat steps 4 and 5.
Omg! Thank you. Literally I was so sad that my necklace broke cos it was of my favourite band. Thank you
Jewelers newer use the needle nose pliers to fix the chain. Unless to put the needle thru the chain link and push inside to open that chain link. They use any different but not needle nose- to squeeze the links back. Best way- to twist the link by two pliers ( not needle nose!!) put thru the chain link and twist it back.
fixed it, but now i cant fit over my head
thanks I fixs it
Now you're ready to flaunt your old necklace once again!
crwdns2935229:037crwdne2935229:0
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0crwdns2947412:017crwdne2947412:0
My chain broke when my 7 year old cousin pulled on it when he was piggy back ridding me. Ha Ha. Only took 20 min to do this. Very easy bit best to have nimble and dexterous fingers
My very new chain had broken a day after my birthday .. and the chain is very special so of course I was panicking trying to figure out how to fix it . I found this website and i fixed it within 10 minutes.
With the smaller necklaces, the broken link always falls off really easily, is there a way to make that easier to fix?
My costly gold chain break down...as it is very lin... How can I joint it
I would like to say that my gold chain down due to its thinness...how can I joint this chain
A link broke in my dogs chain collar. I'm using needle nose pliers, but I can't get the two ends of the open link to line up so I can close it!! I've never had this problem before!
This is so hard to do. I can’t even put the links together.
I acsadently broke my necklace
Jayden ayala
Fixed a link on a bracket today thanks to this tutorial. Very easy took a couple of minuets.9th April 23
I want to say that my gold ring is down due to its thinness... Can you tell me how I can attach this chain?
I got a thin, silver heart necklace from my boyfriend for Christmas. A few months later, the chain snapped completely in 2! I found this tutorial and I managed to fix it in 3 minutes with a pair of tweezers. Thank you!!!
I don't have needle nose pliers is there another way?
I am trying to repair a broken chain but I cannot link because the chain is too too small. I cannot correctly grip the rings with the pliers because of the size. HELP
I lost my necklace in the toilet. Can anyone help me?
When you’re ridding in a Chevy and your pants feel heavy….. diarrhea
Well it didn’t work, and I want my money back. All 1000$ back for my iced out gold chain with real diamonds.
