How to Fix Warped LEGO Baseplates
  1. How to Fix Warped LEGO Baseplates, How to Fix Warped LEGO Baseplates: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grab a pot large enough to place the LEGO baseplate in.
    • Fill the pot full of tap water, enough to submerge the baseplate completely.
  2. How to Fix Warped LEGO Baseplates: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix Warped LEGO Baseplates: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix Warped LEGO Baseplates: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the pot of water on a stove.
    • Turn the stove burner on to medium heat.
    • Heat the water to approximately 100 degrees Fahrenheit. Use a thermometer to ensure proper heat.
    • Do not heat water near or above a temperature of 140 degrees Fahrenheit to avoid damaging/melting the plastic.
  3. How to Fix Warped LEGO Baseplates: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix Warped LEGO Baseplates: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix Warped LEGO Baseplates: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the LEGO baseplate in the pot of heated water for 5-7 minutes.
    • Ensure that the LEGO baseplate is fully submerged for the entire heating duration.
  4. How to Fix Warped LEGO Baseplates: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the stove off and remove the baseplate from the water.
    • Dry the LEGO baseplate using a paper towel.
  5. How to Fix Warped LEGO Baseplates: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Quickly sandwich the baseplate between two flat baking pans while the baseplate is still warm.
    • You can use any two flat, sturdy objects if baking pans are unavailable.
  6. How to Fix Warped LEGO Baseplates: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix Warped LEGO Baseplates: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place two plastic clamps over the two pans to evenly apply firm pressure against the baseplate.
    • If clamps are unavailable, you can use weights to apply similar pressure.
    • Leave the LEGO baseplate in between the pressure of the baking pans for at least 5 hours.
If your LEGO baseplate is still warped after the 5 hours of sitting in between the clamps, repeat process and leave the LEGO baseplate in between clamps for an additional 5 hours.
Nicole DeFer
crwdns2935283:009/26/22crwdne2935283:0
224 crwdns2915208:0crwdne2915208:0
CSU Fullerton, Team 1-5, Bruce Fall 2022 crwdns2935289:0CSU Fullerton, Team 1-5, Bruce Fall 2022crwdne2935289:0
CSUF-BRUCE-F22S1G5
100 degrees doesn't seem hot enough.
michael kithcart - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 54
crwdns2942667:0crwdne2942667:0 3,463
