In this guide, I will show you how to fix and clean your Ducky One 2 SF mechanical keyboard (model#: DKON1967ST). If you use your keyboard daily, then you probably have encountered the sticky key problem before. It is a fairly easy problem to fix and only requires a few minutes depending on the severity of the problem. It is important to note not to over use your rubbing alcohol or water/soap solution. Since this is an electronic device, you don’t want to damage it with liquids. With that being said, there is a panel covering the wiring of the device that protects it from this problem, so make sure when cleaning, keep the Q-tips and cotton balls damp and not dripping with your cleaning solution.
Before starting the disassembly of your device, be sure to disconnect your keyboard from your computer.
Grab the USB-C cable with two fingers and pull it out of the port on the back of the keyboard.
Dip a Q-tip or cotton ball in rubbing alcohol. Any rubbing alcohol is fine.
Using the Q-tips, rub the outside of all the keys that may be affected.
Once you have cleaned the top of the keys with rubbing alcohol, remove the key caps from the switches using the key prying tool.
After removing the key caps from the board, the switches will be available to clean.
Put any dirty key caps in a small glass with a soap and water solution and let them soak for 3 to 5 minutes.
Use an electronics duster or a can of compressed air to remove any hair, dust, or crumbs that may have fallen under the key caps.
Using the Q-tip or cotton ball with rubbing alcohol, clean the top and around the base of the switches.
To replace the key caps, line them up with the cutouts on each switch and push down.
Once you have reassembled the keys, press the ones you have repaired 5 to 10 times making sure you have cleaned and fixed them properly.
To re-assemble your keyboard, put the keycaps on the correct spot of the keyboard and push down to secure the caps.
crwdns2917034:0crwdne2917034:0
Hola,
tengo un ducky one 2 mini y dejo de repente de funcionar una fila de teclas desde la X a la M.
actualice el firmware al 1.10 pero sigue igual.
me puedes ayudar?
gracias.
