Are you experiencing sticky keys with your mechanical keyboards after spilling a liquid on it? Follow this simple and quick guide to help fix this problem with your Corsair K70 RGB Mk2 Keyboard.
Take off all the key caps in the affected area by pulling them off with your fingers.
Wipe down the affected areas and keys with sanitizing wipes and isopropyl alcohol.
Blow dry the affected keys and do not concentrate heat on one spot.
Dip a toothpick’s tip into sanitizing liquid or isopropyl alcohol.
Coat the inside of the walls and press the key down to help spread the liquid.
Repeat steps 5-6 two to three times.
I’ve been doing this for multiple days/nights after a tea spill that made 5 keys sticky. I have used isopropyl alcohol with q tips. Blowing into the switches afterword helps also. For me though, this works for a while until the keys dry and become sticky again. I don’t really know what else to do. Anybody got any tips/fixes?
Try some circuit board cleaner. No guarantees but that might fix it. They usually come with a nozzle so you can really blast it in there as well. If that doesn’t work you’re probably pulling your keyboard apart and replacing the switch.
