How to Fix Plastic Chair Cracks
  1. How to Fix Plastic Chair Cracks, How to Fix Plastic Chair Cracks: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix Plastic Chair Cracks, How to Fix Plastic Chair Cracks: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lay the broken chair such that the crack is parallel to the floor.
  2. How to Fix Plastic Chair Cracks: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix Plastic Chair Cracks: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Wear gloves to minimize chemical contact on skin.
    • Dampen a rag with isopropyl alcohol.
  3. How to Fix Plastic Chair Cracks: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix Plastic Chair Cracks: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Clean the surface of the crack with the dampened rag to remove all dust and debris.
    • Repeat on all sides of the crack (edges and backside).
  4. How to Fix Plastic Chair Cracks: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix Plastic Chair Cracks: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix Plastic Chair Cracks: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply glue between the crack.
    • Then apply glue across the surface of the crack.
  5. How to Fix Plastic Chair Cracks: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Hold the two glued pieces together for 30 seconds to allow the glue to bind to the chair.
    • Do not let the glue dry completely. The wet glue will need to bind with baking soda in the next step.
  6. How to Fix Plastic Chair Cracks: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix Plastic Chair Cracks: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix Plastic Chair Cracks: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pour baking soda over the crack until the glue is completely covered under a layer of baking soda.
  7. How to Fix Plastic Chair Cracks: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix Plastic Chair Cracks: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your finger to distribute the baking soda in order to cover all parts of the crack.
  8. How to Fix Plastic Chair Cracks: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix Plastic Chair Cracks: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix Plastic Chair Cracks: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Allow the baking soda to seal onto the super glue over the crack and wait for the mixture to dry.
    • After ten minutes, brush away some of the un-glued baking soda to check if the glue is solid.
  9. How to Fix Plastic Chair Cracks: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix Plastic Chair Cracks: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the chair over.
    • Repeat the procedure on the backside of the crack starting from step 4 and ending with step 8.
    • Avoid reapplying glue in between crack, since it has already been sealed.
  10. How to Fix Plastic Chair Cracks: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix Plastic Chair Cracks: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove excess baking soda from both the front and back side of the crack.
    • Use water or isopropyl alcohol to remove fine grains around the repair site.
  11. How to Fix Plastic Chair Cracks: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Sand off any excess layers of glue on both the front and backside of the chair using coarse sandpaper.
    • This step is optional and simply helps to return the chair to its original look.
    • It may take a while to rid the chair of all texture.
  12. How to Fix Plastic Chair Cracks: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The crack has been repaired!
crwdns2935229:018crwdne2935229:0
Sumeet Dhillon
crwdns2935283:002/18/20crwdne2935283:0
529 crwdns2915208:0crwdne2915208:0
UC Davis, Team S2-G7, Andersen Winter 2020 crwdns2935289:0UC Davis, Team S2-G7, Andersen Winter 2020crwdne2935289:0
UCD-ANDERSEN-W20S2G7
Do you push the baking soda down into the glue (or into the crack), or just spread evenly on the surface?
Dr John Christensen - crwdns2934203:0crwdne2934203:0
Lem apa yang digunakan (nama lem)
Iwan Toro - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 11
crwdns2936753:07crwdne2936753:0 107
crwdns2936753:030crwdne2936753:0 477
crwdns2942667:0crwdne2942667:0 58,154
