Use this guide to fix the mouse if there is a double click problem on your Logitech G403.
Double clicking is a very common problem for G403. If your warranty is finished, you can fix the mouse by yourself, rather than buy a new one.
You will need a precision screwdriver set to fix the mouse. However, in case your screwdriver doesn’t work, you can look at these pages for help:
Don’t forget to unplug your mouse before you start.
Use a prying tool or your hand to take out both sides of the mouse feet.
Use a precision screwdriver to remove four screws from the mouse.
Slowly open the mouse, and take care not to tear the ribbon cable.
Detach the cable connector.
Remove seven screws from the upper cover.
Remove four screws from the mouse.
Remove the mouse click cover.
Remove the five screws attached to the mouse click switches.
Open the mouse switch using a prying tool or your hands.
Find the place where more tension is needed.
Use a prying tool or your hand to give more tension to the copper piece, making sure the copper is curved.
crwdns2935229:010crwdne2935229:0
crwdns2947412:010crwdne2947412:0
step 8 made no sense and had to google it
rel - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
did you find a video about that? if you could send it pls or if it was some place where talk more about it
Lian López - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Worked!!! I had this problem for years, even stoped playing valorant bacause of that. Thanks
VampireKing - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I could not open these screws :( What are the screwdriver size to open these?
Siim - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
