How to Fix Left Joy-Con Sync Issues
crwdns2937549:0crwdne2937549:0
crwdns2935229:012crwdne2935229:0
Taylor Dixon
crwdns2935283:006/26/18crwdne2935283:0
69.854 crwdns2915208:0crwdne2915208:0
crwdns2935297:094crwdne2935297:0
crwdns2947412:07crwdne2947412:0
What thickness of conductive foam should I choose? There are 3 sizes: 3mm/0.12, 5mm/0.20", 10mm/0.39"
maximaleks - crwdns2934203:0crwdne2934203:0
The space is ~9 mm wide, so I would go with the 10 mm size and you can trim it down if you need to!
Taylor Dixon -
I've got the same problem but with the right joycon but I don't know where the wireless card is, please help
Nathan Currie - crwdns2934203:0crwdne2934203:0
Hello I opened up my left joycon and saw conductive foam inside already! I replaced it with one that I bought on amazon (I made sure it was actually conductive foam). But it still won’t sync. Any ideas? Could it be that little solder bubble that connects to the antenna has gone bad? Should I try to reflow it? I also checked to see if any capacitors in the top of the board were shorted and none of them were. If you have any ideas I would be happy to hear!
Chaim Bendahan - crwdns2934203:0crwdne2934203:0
I opened my left Joycon and found that there is no antenna area near the joystick compartment. It’s just an empty space what should I do, I have the conductive foam but obviously don’t know where to place.
Omar Gonzalez - crwdns2934203:0crwdne2934203:0
Hi I have the white ones that came with the switch oled, I followed the instructions but the antenna isn't where it is in the video.
Nathan gustafson - crwdns2934203:0crwdne2934203:0
This video only covers original left Joycon sync issue. For v2 joycons there should be a different video as it is a different motherboard.
Matthew Ward - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 17
crwdns2936753:07crwdne2936753:0 105
crwdns2936753:030crwdne2936753:0 502
crwdns2942667:0crwdne2942667:0 41,197
